10 minutes ago, zspert said:
Now, what was he trying to address with this trick?     Cheers
Oh no, maybe he thought he was installing a fuel filter.😄
3 hours ago, Racer X said:
This 72 BRE tribute sold for $28,200. Odd things, cars like this. Under the hood it has tubing like the race car had, a continuation of the roll cage and chassis stiffening structure, but it looks only cosmetic. There is no cage structure in the cabin, which looks completely stock.
It also lacks a strut tower bar.
https://bringatrailer.com/listing/1972-datsun-240z-277/
I'm always shocked when I see a seemingly nice Z with lights installed backwards.  It tells me that the owner/restoration shop doesn't know Z cars very well.  What else did they do half-arse?
1972_datsun_240z_1V9A0770-23306.jpg?fit=
With the rust in the roof and the patched-up floorboards - given the last two or thee months of market pricing -  I was surprised it sold for over $18K.
For sure. What is mystifying is how so many people were fawning over it like it was something extra special.
To me, the BRE paint job was lipstick on a pig.
The “3.1 stroker” engine didn’t sound very healthy either. Not enough lope for a high compression engine with an extra lumpy camshaft.
Edited by Racer X
18 hours ago, zspert said:
To change the subject a bit - Had a 280 recently sold on BAT towed to my shop for a once over for the new owner. The car has very low mileage. It almost goes without saying that the rear brakes were frozen. Got the right rear wheel off and discovered this "modification" had been done to the fuel pump.
As these cars age I see more and more generations of butchers plying their trade but this is a new one on me!.
Looks like a fuel pressure regulator. If so, it won’t work without a vacuum signal, eh?
Could be a check valve to make up for a bad one in the pump.  What is on the fuel rail on the engine?
That a fuel pulsation dampener? Guessing it was a fuel injected car?
I can't answer the question, but wondering if it was related to fuel pressure and maybe fitting a fuel pump that wasn't quite right?
Yes, that it. It's the later 1978 onwards fuel pressure regulator. It serves no purpose on the pump. Without vacuum it will provide 2,5barg and you will still need exactly the same thing after the injectors to reduce the pressure to compensate for the vacuum in the manifold.
Someone probably thought the pulsation damper looked like a regulator and replaced it with one. Could have just left it out all toegether. According to the bosch FI manual, the dampers main purpose was noise reduction more than anything else and this system is basically a bosch system.
Maybe just spanning the gap between the old crusty hoses ends.  Looks like a new FPR though.  Strange.
@zspert, that old braided fuel hose could blow, or just slow leak from longitudinal cracks, at any time.  It's on the high pressure side.  I remember that soon after I bought my car, after I had installed a new pump and got the car driving well, I was pulling out of my neighborhood and a UPS truck driver pulled up beside me to tell me that fuel was pouring out from under my car.  A PO had used low pressure fuel line and it had split.  Luckily everything was cold and I was within walking (running) distance to my house where I had some spare hose.  I was able to squeeze under the car which I had parked next to the curb behind a strip mall to replace the hose and get it back to the house.  I felt bad about the big gas stain on the pavement but at least there wasn't a pile of melted plastic and tire rubber.
Edited by Zed Head
add words
I wondered if the "damper" isn't installed backwards? i'm not sure but isn't the lower tube the inlet? Haven't investigate this as i'm a lazybone...
