Skip to content
Ugliest Z ever?
For some folks it's more about the show, not the go.....I think this is one of those.
 Beauty is in the eye of the beholder. Looks like an afterthought to me.
"The only two negative things about the car are: 1. Cylinder 5 is a little weak due to a small bypass on the head. quoted $1200 to get planed and put back together. 2. Tires will need to be replaced. tread is starting to crack.(will go flat from sitting) "
Only 2 negative things???ROFL
And that color scheme... Deep blue with a wide white stripe? Makes me ill.
Who would do that to a Z???     :ph34r:
It might not be the prettiest, but at least it's not rusting away in salvage yard.
I also like the sunroof borrowed from a Winnebago. Must be real quiet at highway speeds.  At least there are 2 more inches of headroom!
