[2026] What Did You Do To/with Your Z Today? - Page 5 - What I Did Today - Classic Z Car Club Skip to content
No, the oil will pour out the rear of the transmission if no drive shaft is installed when it's tilted up. I would loosen the plugs on the tranny and fill it once it's in the car. They make little hand pumps that make this really easy
OK, I have rubber caps, like those that protect the threaded ends of pipes, that I can clamp onto the tranny tail prior to installation.
I wouldn’t advise filling the trans before installation. Plenty of opportunity to do that while putting the cross member and shaft in.
I was going to comment this as well. Aside from leakage out the rear ( 🫤 ), the level/angle of the unit may result in over/under fill. My 2-cents.
I bought a hand-operated transfer pump so I shouldn't have any trouble putting in the 1.5 L of Redline MT-90 when the engine and tranny assembly is firmly bolted into the chassis.
Thanks, all, for the warning about tranny tail leakage as it's not mentioned in the FSM that I have.
I was only reminded because I've drenched a rain coat in 90 weight waaaay back when I was helping a friend replace the clutch in his Firebird. We had the front end lifted and it started pouring out as soon as I pulled the driveshaft. He decided that I might not know what I was doing, which was partially true, and took it home after I put it back together. Good times man, good times...
Edited by Zed Head
whaich > which
Hey, @siteunseen, did you get those in the plumbing department of a big box store? That's what they look like to me.
Either way would you want to risk/ not knowing what the capacity level is once it’s settled in the car. Myself, I need to take that variable out of the equation and know the oil level may cause a latent failure down the road. IMHO
The FSM says that both the 4- and 5-speed trannies take 1.5 liters so that's what's going in when the time comes. My hand pump arrived late yesterday. It's sized to fit a 1-gallon jug but I have to RTFM to determine if it has enough stroke-to-stroke repeatability to let me use that metric. Got some experimenting to do...
