[2026] What Did You Do To/with Your Z Today? - Page 4 - What I Did Today - Classic Z Car Club Skip to content
He has a whole bunch of similar, meticulous operations in restoring his '71.
Painted my freshly bored and decked block. Internals are out for balancing and should be done tomorrow. Then I finally get to start re-assembling!
I found painting my block to be an almost Zen-like experience.
did some scrubbing and prepping of the engine compartment. getting ready for blasting and painting. Gotta have a nice home for the new motor!
Questioning my life choices after deciding to polish all the aluminum bits under the hood; valve cover, intakes, balance tube (cheated on this one and I have a polished euro tube coming from Ztherapy), front cover......
I've already got 2 full days into these parts. I just finished my first pass of wet sanding with 320 grit. I think I'll be able to do 600, 1000 then finish with 1500 before buffing. Most of my time was spent grinding casting marks and trying to make all the fillets uniform radius. Ground off all the words and numbers and the rough cast finish. Drilled and plugged all the holes in the top of the intake flanges with some JB Weld and aluminum round stock and will mill off the extra flange that sticks up above the insulator blocks.
If I ever do another car, I'm leaving them all stock!
It's like remodeling a bathroom. Once you put a sledgehammer hole in the drywall, you are IN, brother.
YEP! After wet sanding to 320 grit yesterday, I was admiring my handiwork, but all I could find were more flaws in my work and in the intake castings, themselves! Now that I am all in, I must make them as perfect as possible. SO.....I'm gonna get back on the Dremel tool today....
I never realized how ROUGH these castings were until I smoothed/cleaned one section, then I realized how much work I had committed myself to!
It will be satisfying to me to know I've got one of the cleanest sets of intakes anywhere, BUT if just ONE person notices and comments someday, it will be the icing on the cake! LOL
finally got the fenders off! I was very happy to see that there was no cancer, and actually very little rust. I did break some bolts off, but that should be easier to deal with than the potential cancer that could have been hiding. cowl area is very clean as well!
took a break from the engine compartment and got the crank installed into the block and pistons attached to the rods. I was extremely happy to see that all tolerances on the main bearings to crank were spot on. Next up on the engine build front is to install the rods and pistons. Head is already assembled, so things should move quickly from here! Now, back to prepping the fenders, fender wells and engine compartment. This motor deserves a nice, new home!
After around 15 years of restomod work, I finally got an engine back into my car. It's a 3.1 L stroker. Oh, that looks so good to me.20260927_142422[1].jpg
Next, I added the Findanza flywheel, clutch disc and Centerforce II pressure plate. Woohoo!!20260927_160747[1].jpg20260927_160832[1].jpg20260927_163124[1].jpg
Feeling omnipotent, I tried putting in the 5-speed tranny and discovered that there is not enough clearance between the 6-into-1 header and the tranny tunnel to allow this to happen. I'd have to remove (and then reinstall) both the exhaust and intake systems to open up the space, so I reluctantly decided to remove the engine and attach the tranny to it off the car. Because I removed the original engine and 4-speed tranny as a unit when I started this project way back when, I should, with the help of an assistant, be able to put the same size assembly back into the car. Indeed, that's what the FSM says to do. So, a bit of a setback, but it's all good, right?
Unfortunately, I then discovered that one of the two M10x1.5 holes in the tranny bell housing where the starter motor attaches is stripped. So now I'm cooling my heels waiting on a threaded insert kit to arrive. At least it gave me time to remember that I needed to put oil in the tranny: Redline MT-90. Better to do that off the car than have a Doh! moment and have to crawl under it to complete that task.
Now to blast and refresh the drive shaft.
Don't overlook sealing the hole at the back of the transmission before tilting the assembly for reinstallation. Avoid oil wastage. I'm sure you had it covered, but just in case.
Do you mean the hole for the breather tube?
