[2026] What Did You Do To/with Your Z Today? - Page 3 - What I Did Today - Classic Z Car Club Skip to content
2 hours ago, Patcon said:
I like the flames you had on the hood
Thanks, They are on the sides as well. When I went Racing Green I had them put the ghost flames back on. Gets a lt of good comments.
Today I buttoned the Z back up for the drive to 7'th Annual Datsun Swap Meet and Gathering. The project included trying to not succumb to carbon monoxide poisoning before making it there. I will be taking my father (the original owner of the Zed) and would like him to not expire on the trip.
The plan was to replace the rear deck inner seal in an attempt to eliminate reduce the amount of exhaust coming into the cabin, I purchased the seal offered by The Z Car Depot and installed it. I also replaced the outer seal with a one piece seal from MSA.
After waiting through the cure time and reattaching the rear deck lid, the outer seal was too thick to allow the door to close anywhere near making contact with the new inner seal. I had an easy 1/4" of air space between the left rear corner of the inner seal and the tailgate. If I removed the lower portion of the outer seal, (up to the point of the original 3-piece early seal) it almost sat in contact with the inner seal. My latch is adjusted all the way down to its tightest position.
The rear inner weatherstrip is just not thick enough to make a seal. I know the Silvermine Motors offers a thick non-OEM inner hatch seal and that might be the ticket. I honestly can't figure how or why a standard replacement seal would be so far off from actually making a seal on this car. I can verify its entire history as straight and clean. The left (driver) side is a little higher than the right (passenger) side but I have attributed that to having a single hydraulic lift on that side.
In the mean time, I have added a 1/4" neoprene seal to the lower underside of the tailgate to bridge the gap and it seems to be working. I still get fumes in the car if I open the windows while driving but it is much better than before. I can't smell anything if the windows are closed with the fan on so I am at least good to go there.
The car has new rear tail light gaskets and being a series one, also has new inner vent flap rubber. I will completely block the inner tailgate venting system similar to how door cards are sealed with plastic and butyl adhesive but have run out of time for now.
The exhaust fumes are a real downer to enjoying the old dog on the road.
Edited by DrFeelGood
That Silvermine seal looks a LOT like the door seal profile offered by Precision Replacement Parts (PRP), which is sold not only by them but many auto parts retailers as well. I hope it might work for you.
It certainly does NOT look like either the OE real main seal or the one that PRP markets, which I just put on my '72 a couple of days ago. I have to say "markets" here because the parts I got from are not made in the U.S. (but not in China either) although they probably are made to PRP specifications.
I do have a question, being a retired research chemist and all: Are you smelling exhaust fumes or are you smelling raw gasoline fumes? If it's the latter, then no outer seal will help as those fumes are coming from the evaporative emissions system (EES) hoses on the rear passenger side of the car. You likely know that after your family has spent 55 years with this car.
If it is exhaust fumes (could be bad grommets for those EES hoses) and you are worried about CO poisoning, there are inexpensive portable CO monitors that you can get. One in particular is being offered by Walmart for $41 and you could tape it to the headliner or the inner side of the passenger seat if you have high-back bucket seats. I don't have this unit so I can't really speak to its utility but I'd suspect that the liability exposure of offering something that, if junk, could wind up killing people is a bit too much for Walmart to have ignored.
I found that new rear taillight gaskets might not be enough. The housings warp and the body is typically not flat where they mount. I used DAP "Seal N Peel" caulk on the tail light gaskets to make sure they're sealed well. It applies like a caulk but is easily removed in the future
Dap 18354 Seal 'N Peel Removable Caulk, 10.1-Ounce
I replaced all the evaporative system hoses and floor seals.
I caulked the area around the filler neck. I also caulked the hoses where they passed through the floor in addition to the new seals.
I replaced the seal at the antennae drain
I installed a repro series 1 hatch panel. When I did I used Peel & seal on that too. I drove the car the other day with the windows down. I don't remember any fumes but I was focused on other things
Edited by Patcon
@Seppi72 @Patcon Thank you so much for the comments and suggestions. I do know the "raw gas smell" well. The plastic evap tank that was standard has been replaced with a later metal can. Combined with new hoses this had remedied that odor. I think I am going to do a rear (series 1) vent delete. I will leave the physical vents on the deck but completely seal the holes (vent and drain) in addition to the interior rubber flappy thing.
Good tip about that CO sensor. I am still paying my brain off (student loans) so I have some mileage yet to get out of the old noodle.
I did look at the tail housings and they seemed fairly straight. A bead of the goop might be in order however to be sure.
Thanks again.
  • 1 month later...
Several members of the Georgia Z Club went to a charity car show. It turns out we were a significant percentage of the cars that showed up. Unfortunately, no one brought a Z31 or Z34, but we had good representation otherwise.
20260829_081331.jpg20260829_081403.jpg20260829_081418.jpg20260829_081437.jpg20260829_081532.jpg20260829_093823.jpg
I’m really beginning to like the hood hinges being plated and not painted. Chime in Guys.
I do too. Although they can be difficult to get fully plated, because the shadowed parts of the hinge won't plate. So some adjustment or barrel plating can help
Our you can do like this Swiss phenomenon does. I stand in awe of his craftsmanship.
That was amazing
