June 9, 20214 yr comment_623125 15 minutes ago, Wally said: wonder why it says to get acetone and remove the green? thanks The green stuff is a protective coating to maintain the friction surface on the flywheel. If not removed before use it will foul the clutch disc. Lacquer thinner will probably work too, but acetone is a cleaner, better refined solvent. Be sure to do a wet wipe/dry wipe for final cleaning after getting all the protective coating off, to ensure it is completely clean. Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623125 Share on other sites More sharing options...
June 9, 20214 yr comment_623138 The green stuff is a protective coating to maintain the friction surface on the flywheel. If not removed before use it will foul the clutch disc. Lacquer thinner will probably work too, but acetone is a cleaner, better refined solvent. Be sure to do a wet wipe/dry wipe for final cleaning after getting all the protective coating off, to ensure it is completely clean.Ah! I had no idea about this cleaning it off business and put mine together as is - a few thousand miles later and no clutch slip yet!! Fingers crossed [emoji848][emoji1696]Ps. LOVING the orange Z@Wally !!!! Orange Zs are 23.6% cooler than the rest! [emoji106] Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623138 Share on other sites More sharing options...
June 9, 20214 yr comment_623140 Fidanza has done a terrible job explaining what the green coating is and how it should be handled. They also refer to installation instructions on their web site but there are none to be found. They have videos on Facebook, but none on their Youtube channel. They're lucky that people like their product because their "media" presence is crap. They've created lots of confusion. This doesn't help you at all Wally. Make sure you get that throwout sleeve right though. Post the number of the kit you got, or a picture, and the parts that came with it. And the bearing/sleeve is just clipped on to the clutch fork, and the fork is clipped on to the pivot ball. They both just pull off by hand. Pull them out of your transmission and take a close look. they should be cleaned up anyway. https://www.facebook.com/FidanzaPerformance/videos/1583594301777341/ https://www.fidanza.com/ https://www.classiczcars.com/forums/topic/61251-is-my-clutch-seized-to-flywheel/ Edited June 9, 20214 yr by Zed Head + ing Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623140 Share on other sites More sharing options...
June 9, 20214 yr comment_623141 1 hour ago, Wally said: is this what you are referring to? they fit pretty good. there was some glue included i assume once you figure out which holes to use you permanently afix the dowels. wonder why it says to get acetone and remove the green? thanks Yes, the step of the dowel pin should sit flush with the flywheel surface. Do NOT use the locktite that comes with the pins. It is only used with the non-stepped pins such as the oem nissan ones, not necessary since the stepped ones are captured by the pressure plate and can not come out. I had problems with the pins fitting and it was not the flywheel. Two of the three pins would not go in, I assume a qc problem with the supplier of the pins. Almost sent them to Capt O for lathe work. lol Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623141 Share on other sites More sharing options...
June 10, 20214 yr Author comment_623204 15 hours ago, Zed Head said: This doesn't help you at all Wally. Make sure you get that throwout sleeve right though. Post the number of the kit you got, or a picture, and the parts that came with it. And the bearing/sleeve is just clipped on to the clutch fork, and the fork is clipped on to the pivot ball. They both just pull off by hand. Pull them out of your transmission and take a close look. they should be cleaned up anyway. here is the package https://www.ebay.com/itm/324528069103?fits=Make%3ADatsun&_trkparms=ispr%3D1&hash=item4b8f6159ef:g:XUkAAOSwNJ5Zfp9G&amdata=enc%3AAQAFAAACwBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickk5v8gVt3hEWLVg%2F253w6XCQMvAJfq2JiGyb0i0lc9YJpUTDAr5BnIOLesbBYyfNjX2642uJ4Tnh6rVEoXglJ2T39wLKGcvvvfutk%2FkL8qQJdAkR3ZINmgWuf6AvtI351wmtYk6g7HX9QpGmGlB4b0OukRzscS0vJ4gO7s4gEDL1erD94WL90iCn4TGC3ukFhvbcdK%2BtqeQTTtrU9OODyxEteBSC0ASgyf5u6nFcbdCAb3vc1O0t3nl962RzREOdPzNvbeT5WyIXQjxSiCo3DCCTfQLeBqhjD7MPzhVW0DuQgb96drWxGYF4hm3LpIkBdfclCRwF9sig3u%2B9Dnm5FA0FX%2BjI5AzNr8TxQbaoWbnvnqycU9SbFYg4GtvsKZLe9lmXz4IQac1zGJZAkaXtHt7euLC%2FPrHZZcT4wYFbEXdlFxb%2BbtuOIFMvF2XhkRujXDg9zMQnOH5HUt3Y01zLTXtt5VUMS7nezslszpV2AHFr%2BjIBsUfvGNA5PKJ2oiPM89VQVsgSLrzgXRBG6a%2BrNfI5COGPmyNOi7lCaMvz0VQmImQZCjd77gwR09wzEgHfRo%2BABS94DysuvUdXzapQ9OpEAVLn2Lo%2BCoSJXKsXHxopmyiEDoRd1oUnrbjtslk076fWS7GlP0sKHlyOLvYxfyg0u1ptVkggxO2NjgfGKp3eBGBp%2F6EgWQxnlXmMM%2B0RQRiIfuRrlQKrUs0tNm%2BOtDdPm0uZKg46EXUB6JV6BPr4dd%2FilA6ElZJHeUSs%2Fef1GMjr9qO2vWc55Ky0x83IcUupz%2BGV0ImHk9zP5eGWo2u13RmRvAwI4KrFed5pNZf7M3Vq%2FyQHsDmCJ%2BLcXxvSx0VrNOkFPexIooZhAkyqWAoxdpsUiPtrmthkaxDNlKsa56|cksum%3A32452806910333f38dc307e44b53938d38020f0444df|ampid%3APL_CLK|clp%3A2334524 and here is the sleeve i bought https://zcardepot.com/products/clutch-throwout-release-bearing-sleeve-oem-240z-260z?_pos=10&_sid=6d7b4c52d&_ss=r Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623204 Share on other sites More sharing options...
June 10, 20214 yr comment_623220 The 2nd post in the thread below has some good information. Take that measurement and see if you get close to 92 mm. Make sure the throwout sleeve is right for the pressure plate. Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623220 Share on other sites More sharing options...
June 10, 20214 yr Author comment_623222 roger that. got the bearing and sleeve all off and on no issues. It was quite simple. THe seal or bearing on the other end though by shifter....should i replace it? is it easy to? whats it called? Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623222 Share on other sites More sharing options...
June 10, 20214 yr comment_623224 I would. They're only about $10 for a Timken. Chain parts store have them or can overnight if not on the shelf. Seems like I bought mine from Advance or O'Reilly's. Could've been a National seal? One or the other. Edited June 10, 20214 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623224 Share on other sites More sharing options...
June 11, 20214 yr Author comment_623268 i tried to find it on zcardepot. do you know what exactly its called? they have some called front seals, rear seals ..... Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623268 Share on other sites More sharing options...
June 11, 20214 yr comment_623270 RockAuto carries them. Called "Main / Output Shaft Seal" , the National Brand # 710324 costs $4.20 each + shipping. https://www.rockauto.com/?carcode=1209260&parttype=8792 Edited June 11, 20214 yr by crayZlair added link Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623270 Share on other sites More sharing options...
June 11, 20214 yr Author comment_623275 thanks. Got it ordered. should i put grease in everything around the sleeve and fork. Also this might be a good time to drain all the tranny fluids? Anybody used seafoam? been hearing thats good to use but what i saw said automatic transmission on bottle...i have a standard Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623275 Share on other sites More sharing options...
June 11, 20214 yr comment_623283 I use this and think most people do too. Manual transmission. https://www.amazon.com/Red-Line-50304-Transmission-Transaxle/dp/B000CPCBEQ/ref=sr_1_1?dchild=1&keywords=redline+mt90&qid=1623436601&sr=8-1 Some instructions while you wait on delivery to read over. Thanks @240260280 https://atlanticz.ca/zclub/techtips/mtl/index.html Link to comment https://www.classiczcars.com/forums/topic/65264-clutch-kit/?&page=3#findComment-623283 Share on other sites More sharing options...
