"The only two negative things about the car are: 1. Cylinder 5 is a little weak due to a small bypass on the head. quoted $1200 to get planed and put back together. 2. Tires will need to be replaced. tread is starting to crack.(will go flat from sitting) "
Only 2 negative things???ROFL
