Darn Tire Jockeys - Page 2 - Open Discussions - Classic Z Car Club Skip to content
Darn Tire Jockeys
With the flat portion of the roof, it looks a little like a sketch of the 2+2.
Edited by Captain Obvious
more detail
16 hours ago, Zed Head said:
I had thought about making some slotted rubber pucks for the rocker panel seams but at home I just used the diff or the front cross member and the sub frames were dented anyway.
I wonder how well a Z would lift using the four points shown in the Owners Manual. Is that not the ugliest drawing of a Z ever? 1973 Owner Manual. Looks like the summer intern did it.
Yeah this would be awesome. You can probably start with 3D printing prototypes. I know BMW has something similar with an adapter that can be mounted in a standard hydraulic jack. I believe it's called a "Jack Pad" or similar...
I've been using slotted hockey pucks as lift pads for several years. They work quite well. Just make sure that the slot is wide enough to keep the puck from wedging itself onto the pinch weld strip and deep enough so that the load is taken by the rocker and floor panel metal on either side of the pinch strip (rather than by the pinch strip itself).
I think I'll just stick to the rear differential or the front crossmember pad, never had a problem with these points.
I ran into this at a local tire shop: Several years ago I had them install tires I purchased elsewhere and they were happy to do it. I told them I wanted them to use a floor jack and lift by the front crossmember for the front tires and by the differential for the rears. They did exactly that. A few years later I went back and asked them to do the same thing and they would not - telling me that new corporate guidelines prohibited using a floor jack - they could only use the installed lifts.
You can do that at home and possibly if you find a small shop that will agree to that method, but most of the large chain tire shops will probably not. Couple that with a crop of installers only used to dealing with modern cars...
The damage to the above fender was done by failing to use an extender under the pad at the end of the lift arm. It's the lift arm that did the damage because it wasn't properly spaced to avoid contact.
  • Popular Post
The last time I got tires I took the wheels off the car and went to the tire store. They did mount and balance (no outside weights), I took them home and put them back on the car. No issues.
That’s exactly what everyone needs to do.
story..
I always do tires myself in a friends shop.. he does my APK sort of MOT.. AND i'm ALWAYS PRESENT once a mechanic wanted to do to my 300zxtt what go's wrong with every 240z engine beams.. i was furius and it did not happen as i refused it. i really had to stop him! it would have ruined my perfect 300zxtt!
BUT..
But we have a big tireshop here in the village..
I needed a new tire on my wheelbarrel..
So i took the old one off and cleaned up nicely my rim, sanded it and painted it the original red color..
I went with it to the tire shop and asked the boss himself if he had a tire for me, yes we have, give me the rim and i install it for you for free!
I said: no not necessary! I rather do it myself!
No,NO,... he insisted..
He ran from his office to the tire shop and started work, he had in no time the tire on, at least that's what he thought.. on the lower side the inner tube was still hanging out.. every body knows what happened next haha, luckely i was standing on the other side of the shop. he started to fill the innertube and .. KABOOOEEEMMM !!!!!!! that was the end of my own inner tire!
Now i got a new inner and outer tire for the price of a outer wheelbarrel tire.. but it shows how much go's wrong at firms with decades of experience...
At least he didn't scratch the new paint! 😊
Also.. mechanics that check wheelbearings and stuff around the wheels with a tire iron and using the aluminum rims as a base to put force on something.. if i see that happen i'm asking him to stop or i'll put some force to something HE does not like! ;-)
For the last 30 years i had a mechanic that did every APK (sort of MOT) every year on every car i have together with me and it has been GOLD. evry check-up costed me the standard 40 bucks and away i was, good for another year or even 2.
Now these days cars of 50 years and older do not need any APK ( periodic roadworthiness inspection) .. and i think it's nonsens.. Our government thinks that people with that old cars are so much caring for their car that it does not need a inspection.. which i think should be at least every 5 years or so?
In our country, things like shown in youtubes american " customers brought in" or something.. does not happen here.. i saw some cars in that "show" without any frooring in them and completely broken beams, gearboxes and and..
If a car in the netherlands has a rusty spot/hole as long as say 5 inches it's not roadworthy, it's illegal to drive that car any longer and you get high fines if you do. it first needs to get fixed properly!
  • Popular Post
Too funny! 😂 I routinely see cars with large rusted holes in them. They seem to work fine. Also in my state there are zero vehicle inspections! No smog, no emissions, no brake light check etc. It doesn't seem to create carnage on the roads. What does seem to create great issues is the invention of the smart phone! Which some drivers can't seem to put down long enough to get to where they're going!
In Utah we have no safety inspection anywhere, emissions are by county. In the counties that are trapped between 2 mountain ranges they do have emissions inspections and it so happens that the trapped counties have the majority of the states population. If you cause an accident due to some safety issue you didn't get fixed it's not pretty. Rust... Yea, we got plenty in northern Utah where they use massive amounts of salt when it snows (plenty of salt beds around the Great Salt Lake). I really don't see safety issues other than cuts if you grab a rust hole.
Forgot to mention that vehicles registered as vintage 1982 and older do not require emissions. Vehicles 1973 and older are allowed to use license plates issued for the year of the vehicle if you can find them.
