Brake fluid leak at master - Page 2 - Help Me !! - Classic Z Car Club Skip to content
The rear reservoir would be for the front brakes. Unless you mean the reservoir for the rear brakes when you say rear reservoir.
Neither reservoir should be pressurized. The pressure should only be created by the pistons in the MC bore.
If you had moisture in the brake fluid it wouldn't be a surprise to have corrosion in the bore after 6 years. Then when you pushed the pedal to the floor you might have damaged the rubber seal inside.
So, loose fitting allows reservoir ro leak dry, pedal goes to floor because of it, damaging MC seals, new MC leak looks like old fitting leak. Should have got that fitting tight the first time. Seems like it was very loose. Oh well.
17 hours ago, chaseincats said:
I noticed the bolt that screws the rear-wheels' brake line into the bottom of the master was wet and could be tightened a good 3/4 turn
Sorry, I was referring to the reservoir for the rear wheels when I said 'rear reservoir.' Alright, so hopefully the new master fixes the issue. I just don't understand how both wheel cylinders and the master all went out at the same time...
Do you think the positive pressurization in the reservoir is due to the possibly blown seal in the master?
Some copper flare washers can seal metal to metal connections.
No, Pretty sure you’re MC is bad
it sounds like pressure is escaping the master cylinder and sneaking into the reservoir which is forcing fluid out of the bottom maybe? Because of that, sealing that might be counter productive is what it sounds like.
3 hours ago, Captain Obvious said:
Can you take a pic of where it's leaking?
Sure!
It is leaking where the brake line bolt screws into the master cylinder on the forward reservoir (the one that manages the rear drum brakes)
The angle of the brake line tubing itself should be straight going in. You need to manipulate that line where its dead center going in. You mentioned it didn’t leak before but I think you may have had luck on your side.
Yeah, you're right, it does look crooked...I wonder how it didn't leak for 6 years if it was like this. I'll install the new master this weekend anyhow since I already bought it and report back on the state of the threads, etc.
Edited by chaseincats
It's quite amazing the problems in the plumbing world that arose with the change of season. Especially when the atmosphere went from warm to cold...
I 100% agree but in this case its been 6 full years without leaking
