July 9, 20187 yr comment_552734 1 hour ago, siteunseen said: I am thinking of Moelk, we have the same cam kit. Sorry. I have schneiders stage 3. Its a very mild cam. //Andreas Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-552734 Share on other sites More sharing options...
July 9, 20187 yr comment_552739 Mine is what MSA calls a stage 3 like Moelk's. It's Schneiders 270/80F grind. Sounds like I'll be using the E31 as I've planned all along. I'm not looking forward to grinding those .190" lash pads down to size, I think will be .175 or .180. Thanks guys! Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-552739 Share on other sites More sharing options...
July 10, 20187 yr comment_552803 Installed my Recaro seat I found on Craigslist. Feels and fits great. Put my 240Z sliders on it. Did not come with any. Â Â Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-552803 Share on other sites More sharing options...
July 11, 20187 yr comment_552819 Looks good.  How much space between the seat and steering wheel? It looks like it sits a bit higher than stock. Dennis  Edited July 11, 20187 yr by psdenno Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-552819 Share on other sites More sharing options...
July 11, 20187 yr comment_552833 2 hours ago, psdenno said: Looks good.  How much space between the seat and steering wheel? It looks like it sits a bit higher than stock It does sit higher. I added all the plastic spacers on the bottom mounting studs. Easier for this these old legs to get in and out. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-552833 Share on other sites More sharing options...
July 14, 20186 yr comment_553055 rebuilt 15/16 brake master cylinder installed: -- new rear brake hoses -- new calipers -- new brake booster -- new brake master -- new clutch master -- new clutch slave -- new clutch hose -- new hose clips Janet! I need you to help bleed the clutch! Waiting on front brake hoses to finish the brake job. All new hydraulics will be a treat. Blue always had a leaking booster so power brakes for a change will be nice.  - brembo brake rotors weathered the 10 years in the elements nicely; just surface rust - Sumitomo S-12 calipers has rusted body and seized pistons - clutch slave had rusted pin and a slight leak - clutch master had a slight leak - brake master had the top caps rusted - rear drum brakes were great  Edited July 14, 20186 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553055 Share on other sites More sharing options...
July 15, 20186 yr comment_553101 Mechanical: - Valves adjusted - Cam looks fine - Made new gaskets for oil bar  Electrical: - Tail lights now work - Key now starts car - New alternator now charges battery On Deck: - about to practice Mig welding with C25 for first time.... holes in floor be warned! Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553101 Share on other sites More sharing options...
July 18, 20186 yr comment_553406 350km total drive to and home from a car meet today. Over 30 degrees celsius. Car didn’t hesitate even once. The heat shield i built for the carbs workes i guess. I on the other hand was sweating like a ——————  Edited July 18, 20186 yr by moelk Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553406 Share on other sites More sharing options...
July 18, 20186 yr comment_553418 Getting the 72 ready for motor extraction this weekend.  I don’t have plans to paint the car anytime soon but will go ahead and detail and respray under the hood, no better time than the present. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553418 Share on other sites More sharing options...
July 19, 20186 yr comment_553433 Had a clunk in the rear end on big bumps. Think I found out why! Other side was not much better.  Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553433 Share on other sites More sharing options...
July 19, 20186 yr comment_553496 22 hours ago, scotta said: Had a clunk in the rear end on big bumps. Think I found out why! Other side was not much better.  Wow!!! Good catch! Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553496 Share on other sites More sharing options...
July 19, 20186 yr comment_553498 Â - That'll do it! Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=15#findComment-553498 Share on other sites More sharing options...
