Hello lovely people,
i search for an older thread as someone had already done some experiments with the FS5C71B europe transmisison.
I drive an 73 240z from Europoe and my transmission 5th gear pops out. ( its not just only the main shaft nut whicht needs to be tighten)
If i tighten the mainshaft nut - It seems to be that the last washer on the mainshaft is to tight so the gears get blocked.
And someone was able to create a small brass spacer and placed it between the last washer and the main shaft gear bushing.
If someone finds this post and or knows the person who has done that - that would be nice.
He also postet a lot of images of this rebuild - if that helps.
I would love to understand if the fix is still valid and if he faces some other issues.
Best Roman
Edited by wutsin
