On 11/29/2022 at 8:48 AM, SpeedRoo said:
Looks like it has the factory rubber bushings on the mustache bar.
1970_datsun_240z_1606-Gold-0167-scaled.j
Factory bushings likely yes, but not the early type with formed over flanges and straight cut serrated rubber washers. This one has the later wavy washers. Here is a good discussion on the subject.
Edited by CanTechZ
All that effort to refinish the suspension pieces, re-plate the hardware, paint the yellow assembly marks, and didn't paint the part number on the mustache bar.
Edited by 26th-Z
What would be the correct number @26th-Z ? Is this the correct one, it's off a Aug 1970 build.
Edited by SpeedRoo
5 hours ago, SpeedRoo said:
Great observations, please keep them coming.
The inner tail panel, when did it change over to covers for the taillight access?
TS70-42 8 Oct 1970
Cars with Black Interior Trim
HLS30 02830
HLS30 03327 - California Models
Cars with Brown or Blue interiors
HLS30 03881
HLS30 04364 - California Models
On 11/29/2022 at 5:45 PM, Carl Beck said:
I don't believe that the Top Lid to the Battery Cover was vented (with holes) until much later.  While it looks like NISSAN OEM Spark Plug wires were used - the later OEM Replacement Parts for a time came with Red Spark Plug Boots - the originals and later OEM Replacements were all black.  May have been mentioned, but as I recall those are the wrong hood bumpers for 01/70
FWIW...the battery cover lid that came on my 12/71 car does not have vent holes.
Recently replacements (now NLA) from the likes of Motorsports Auto, JDM-Car-Parts and 240Z Rubber Parts appear to have the holes.
https://jdm-car-parts.com/collections/electric-components-nissan-datsun-fairlady-z-240z-260z-280z-280zx/products/original-battery-cover-set-datsun-240z-260z-and-280z?variant=731360985
I keep referencing to the close to original Green May 1970 240Z "04684" to work out what is correct or not. Should the fuel pump be Nikki on early cars, also should the clip on the hose connecting to the fuel filter be a wire clamp or band type? Were the wire clamps gold zinc or clear? Or a combination?
Searched back through the forum and found the correct fuel pumps. Should be a Nikki on the BAT car.
Nikki is OE for 10/69 - 5/72
Atsugi for 9/72?
Ampco is OE for ?/73, possibly also a later replacement
Kyosan Denki is a current replacement
P/N 99999-20015 (a.k.a.) the Nissan Service Manual for Model L20A, L24 Series Engines, Page ET-5 appears to show a clip style clamp on the outflow part of the fuel strainer.  It's hard to make out in the photo, but it looks like the typical Philips head wire band hose clamp from the hose to the fuel pump side.
So the green 240Z appears to be setup closer to the original.
Edited by DatsunZGuy
It isn't phiLLips.. It's a JIS.. see:
That Phillips-head screw isn't what you think it is - Hagerty Media
It took me also a lot of years to GET that!  These days i have the apropriate screwdrivers in house and it's just a better fit!
(I thought i just say this , because we are nitpicking anyways here.. haha 🙊)
NICE article from Hagerty, well explained. 👍
Exactly.  I firmly believe that is the reason so many of the heads on the carbs, hose clamps, etc are so screwed up (pardon the pun).  It is because someone used a Philips head screwdriver. JIS fits the head.
That is a good read from Hagerty. I learned something new today. I've never noticed the dot on the heads of screws but found it interesting and then I saw this picture that @HS30-H posted and was perplexed (as usual) by the dots in his photo. There's one with a single dot, the others have two. I'd like to learn more. Hopefully someone knows the story better? Thanks anybody that might share some information with me/us. Cliff
Edited by siteunseen
