16 minutes ago, siteunseen said:
Are those plastic toggle switches still available from anyone?  I've got 2 lights with those broken off, not on either car of course so no biggie just curious.
Not to my knowledge.  Our good friend @S30Driver has substituted modern switches with a metal toggle with success.
Holy crap that is a lot of inspection lights. I just finished restoring 2 of them. They turned out fairly decent.
Does anyone know if there is a source for the rubber grommet on the bottom where the wires exit. I’m sure I saw them advertised somewhere before.
11 hours ago, AZDatsun said:
Does anyone have a web link to the more modern metal toggle that will work I think a lot of us have broken toggles
@S30Driver - any recommendations?
I have a grommet assortment box from Harbor Frieght, found a size that works well.  I do open the center hole with a drill bit to handle the connectors.  You probably don't have HF in Canada but likely a similar outlet.
Thanks.  I think Princess Auto may be similar to Harbor Freight.  I will give them a try.
Nice de-fangeling Jim!
The ones I purchased are not available at this time.  This is roughly what you are looking for, a SPST on off toggle switch, the hole for the switch is 12mm,  I would probably solder the leads instead of using the screw terminal and remove the on off plate.  Not sure about the quality, but you get 5 for about 10 bucks.
https://www.amazon.com/Nilight-Rocker-Toggle-Switch-Waterproof/dp/B078KBC5VH/ref=pd_ybh_a_3?_encoding=UTF8&psc=1&refRID=BGC5ZQ1MQTNHNWVSJWKE
Edited by S30Driver
addition
From grunge to glitter!  Next up - Dremel wire brush to clean out all the insides, then wet sand final prep for handoff to the plater.  I was pretty lucky with this group, only one body had a couple of dings and only one had any serious patina issues.
