27 minutes ago, jwtaylor said:
"Hold that damn light still!" was heard many times in my early years. When he would finish a repair I was put in charge of cleaning all the tools and putting them away.
I remember my older brother and Dad were swapping a clutch. I jumped in the car, pushed the clutch to the floor, blowing out the slave cylinder. I got out of the car and started running! Fun times. My Dad is now 87 and loves to brag on my mechanic ability. He's my biggest fan.....now. Lots of great memories.
So I need a little help. I still don't have turn signals even with a new electronic flasher. I have tried a three wire with a ground and a two wire. I will save that for Cody at the moment.
The other problem for the day is reverse lights. The switch I have has the leads torn off. So I ordered a new one for a 280zx transmission from a Z vendor I bought a number of things from and like doing business with. The new switch does not trigger fast enough. That is to say the plunger has to travel too far to make the circuit. It appears the plunger is brass so that seems to rule out adding metal to it with the welder. Is there another way to source a better switch? One that needs less travel or one with the plunger a little longer... The switch needs to trigger before the length is below 0.73". The new one needs to travel about 0.125" more to trigger
I'd be surprised if you couldn't still get one from Nissan but my local O'Reilly's can get an aftermarket one in store in an hour for a stock transmission.
(also, if you dig away the black goo that the two wires come out of on the original switch, you'll find a couple of brass solder tabs in there that what's left of the wire will still be soldered to. a bit of wire and a male and female bullet connector (with insulators)... Fill the cavity back up with silly cone - just sayin')
Edited by cgsheen1
I went through some weird blinker issues and it turned out to be a connector pin in the harness near the glove box had pushed out of the connector. I think I have a large laminated wire diagram if you need one.
Thanks Ernest, I have the large laminated wiring diagram. Makes tracing much easier
So I tinkered with the flasher relays some more. I had a 3 prong one that required a ground. I couldn't get it to work no matter how I wired it at the bench. The two prong works fine with an LED bulb at the bench off the jump box.
So I tried it in the car on both the turns and the hazards.
With no relay in place I basically have battery voltage coming to the relay. When I plug it up and try to use it the voltage across (? I don't believe this was to ground...) the relay drops to less than 8 volts in both locations. So I am assuming neither the LED's or the electronic flasher will work at the low voltage???
Where to from here?
@SteveJ others?
LEDs aren't very voltage sensitive. I'm trying to figure out the voltage drop, though. Maybe I can get out to the garage tomorrow and take some meter readings for you to try to replicate. I'm wondering if the hazard switch may be corroded/crudded up enough that it's a choke point under load.
