1971 HLS30-14938 "Lily" build - Page 113 - Build Threads - Classic Z Car Club Skip to content
'Make damn sure your sparks are right before you start messing around with the fuel'.
Butch Bohunk, Master Mechanic, Finzio's Sincair Service
  • Popular Post
Last weekend we worked in the shop some
Here is a seam in the leather fender covers. I made this with contact adhesive and clamps. I picked the padding out in the seam area so it was just leather to leather.
We took Lily down off the cubes. A lot less sketchy than the way I put her up there.
Still had to have a 6x6 on the jack saddle at this point
Rolled her outside and it promptly rained...
My windshield leaks and I will add some sealant under the weatherstripping soon.
I also ordered tool covers for behind the seats from Zcardepot. They don't have the hinges. So they may not work for me... Since I don't have the old covers
So, exactly how did you get her up on the cubes?
Car looks great, BTW. That's a nice shade of yellow. Will you eventually paint the front spoiler to match?
Yes, nice shade of yellow. Looks a lot like mine. This is a Chevrolet color...'Rally Yellow'
I had her up on jack stands and stood about a 12" piece of 6x6 up on the jack and lifted her up. But the block and jack wanted to slide out once she was up high enough. I had to hold the jack in place while someone put the cubes under the tires
Yes, the plan is to paint the airdam too. Hopefully it will stick...
Is it urethane or fiberglass? Mine is urethane, I caught a flying 2x4 on the left brake vent hole in the airdam @ freeway speed (at first I thought it was coming through the windshield). I now have a starburst in the paint but that's it. My paint is a single stage and we did it back in 1991 so the only details I remember is I called the Denver regional office to get the paint number for a red 1971 early 240Z. the red does have some orange in it, I think code 110.
The airdam is urethane. It can be tough to get paint to stick to it because it's so flexible.
I used this on my front air damage prior to paint. Can't remember who recommended it, but seems to work.
You might also consider using vinyl paint. I used it to re-colour my Z's interior (from black to butterscotch). Pix below should give you an idea of the flexibility and adhesion characteristics (I've seen zero evidence of paint lifting over the ten years since I originally did the application).
It sprays on easily using an HVLP gun and doesn't require much in the way of surface prep. It took me three coats to achieve full coverage over the black soft and hard trim pieces.
We had a supplier in the Toronto area (Parasol) who would custom mix colors from a customer-supplied paint chip (my results we spot-on, based on a small piece that I snipped from the hem of my new butterscotch seat covers). I expect you'll be able to find a comparable supplier somewhere in the U.S. south-east.
The painter who painted the loose panels for Lily uses Bulldog adhesion promoter. I will talk to the paint shop too. To try to check all the boxes
With all the plastic on cars today, I would think a good body shop would know how to make it work. I had a plastic bumper on my wife's car repaired and painted about 7 years ago and haven't had any issues.
