Interesting way to break a thermostat housing. - Page 2 - Open Discussions - Classic Z Car Club Skip to content
9 minutes ago, Captain Obvious said:
No, it's not the wrong sensor... It's the aftermarket replacement that is (almost) "form, fit, and function" compatible with the original.
Damn it man!
Our timing is off. LOL
You do you. I'll keep using the two piece model my L28ET used originally. I did have to replace it a few years ago.
None of the pictures really show signs of what might have happened. If the sensor was too long it should have a mark on the end where it contacted the other side, and there should be a mark on the other side where it contacted.
The lengths from the seating area look similar but hard to be sure. Might be that the new one just slipped past the seat, the tip hit the other side and it just pressed that threaded area right off. A caliper or another test fit would tell.
Edit - Could also be that you got your wrench jammed against the plug in the adjacent hole and you sideloaded it. It is a nice clean fracture.
Edited by Zed Head
Obviously you have a new housing on the way. Install the factory style unit and call it a day. Way too many variables to continue to diagnose what actually happened. IMO
The next guy that needs a sensor will appreciate knowing if this one doesn't work. Do it for the next guy.
I should get the replacement housing in somewhere in the coming days. When I do I can investigate properly what happened.
I didn’t use too much force and the socket wasn’t pressed against any of the other sensors. It might actually be a casting fault from Datsun/Nissan or galvanic corrosion as the sensor looked original and probably was never replaced before. Also one of my local club members noticed a crack at the same place mine broke on one of the 280z housings he had lying around.
Yes! Could've saved me some antifreeze and the resulting clean up of said antifreeze. My dog goes down there alone 3 or 4 times a day to go outside through his "doggy door". I worry messing with antifreeze because of him and his always hungry personality. Could be another Jamestown someday? unsure
As @Captain Obvious pointed out, the beveled area makes the seal. When I was you were installing the temperature sender, I couldn't tell you couldn't tell that it had made full contact since it didn't feel that tight on the housing, so I gave you gave it one more twist, causing the beveled area to push hard against the housing and providing the leverage to break the housing.
Of course, this is sheer speculation and not based on ANY personal experience.
I saw the hint you dropped earlier and I was wondering if we were gonna get more of the story!! Hahaha!!! 😀
If, in fact, it had actually happened. Which it didn't.
