The time has come for Zedyone to really look at brakes. - Wheels & Brakes - Classic Z Car Club Skip to content
I have loved and enjoyed my Z since 2008. It has been a loyal friend to me over many many many miles. The other day I was driving her round and the brake pedal was starting to feel a bit hard. I mean hard in a way where no matter how hard you mash the pedal, the braking force does not increase. I find this entirely unacceptable. I am currently 100% stock. I have refurbished front calipers and OEM stock (but not original) rear wheel cylinders/drums. I think the time has come for me to take a serous look at my brakes. The time for another Zedyone Build thread is YEARS overdue and this is something I have always wanted to do. My options include:
1) Complete overhaul: Front redo/rear disk/larger master
2) Just do rear disk conversion (probably end up doing CV conversion as well from u-joints)
I worry about needing a larger master to handle rear disk brakes.
I have looked at Wilwood conversions and some from silvermine, etc. All appear to be the same thing packaged a bit differently. But I do think the time for 4 wheel disk brakes has come.
is there any advice from my Z buddies on this conversion. I want to entirely rejuvenate my braking power.
Front Willwoods are an easy install. Fronts are where most of your stopping power is. I just put the fronts on all but one of my cars…..they will really put your head towards the windshield. I use my stock Master cylinder with no problem even with the Z with front and rear Willwoods. A hard pedal usually is caused by a lost reaction disk in my experience. Don’t know what else causes a hard pedal.
I haven't posted in a while.....hope life is treating everybody with kindness
The single best thing I have done to my braking system was to install a larger 8" brake booster. Best of my memory 69-72's had a small 7" booster. Nissan updated the 240 brake boosters to a 8.5" in '73. They knew the boosters were to too small and corrected the braking problem. You also may want to inspect/replace your brake booster check valve. I did go a larger caliper but never got that great breaking feel until I completed this upgrade several years ago.......This made a HUGE DIFFERENCE in my braking power.
JDM-Car-Parts use to have an upgrade for 69-72 that had the correct bolt pattern to accept into the firewall. That made the transition from a 7 to 8" a breeze for me with no extra drilling.
https://jdm-car-parts.com/products/datsun-240z-1969-1972-8-inch-brake-booster-upgrade-kit?variant=31778739748973
Front willwoods look awesome. Will they fit under a 15" panasport though. I have no desire to change wheels. I love my old panasports.
Reaction disk had occured to me, but I was under the impression those fall out during installation. IF it was right for years, how could it fall out now? I need to go back to the manuals and check.
8.5" Brake Booster Upgrade Kit for Datsun 240Z 1969-'72 New Version – JDM CAR PARTS
they do still sell a 8.5" brake booster that uses factor that its a bolt on with 'no siginificant modifications' . Sounds like it may require the 70/71 Z's master mounting holes be be drilled out a bit like so many other kits.
I will run the vacuum checks on my check valve this week to see if it in fact malfunctioning. I replaced it a while back with a new one when I installed a refurbished brake booster back in 2013 or so.
I have front Willwoods on my silver Z with 15 inch Panasports. Probably right about reaction disc….won’t just fall off if you haven’t removed booster. I guess hard pedal could be a bad Brake Booster or check valve.
The reaction disk won't just fall out all by it's own. If this problem occurred all of a sudden, it's not the disk.
A torn booster diaphragm will cause a hard pedal, and so will a malfunctioning poppet valve inside the booster. Either way, you're opening or replacing the booster.
Oh, and I'd be hard pressed to believe it's a malfunctioning check valve. If you're off the gas pedal when you're on the brakes (as you most likely are), the check valve won't really matter because the manifold vacuum is high (because you're off the gas pedal).
Does the idle go up a little bit when you press the brakes sitting at idle? That's a typical sign of a torn diaphragm.
Sounds like you're saying things have been just fine then something changed. As opposed to the brakes having always bothered you. If it was mine I'd find the source of the sudden problem before "upgrading" anything. Otherwise you could add the upgrades and end up with the same problem, never solved.
You are correct, I always has a very good pedal feel and then I did not. I think part of the issue is a bad check valve, and here is why I say that.
I ran the check valve test with a vacuum gage installed down stream of the check valve in between the check valve and the brake booster.
Warmed up the engine
Let the vacuum gage settle down to about 45 mmHg or so (I think that was the number)
Shut off the car and watched. The needle proceeded to drop and drop and drop and drop down to zero after about a minute or so. If memory serves last time I did this test, it held.
So I ordered a new one. I will have to see if this helps or not. Either way, I suppose it is time to change it out as I installed that one back in 2009 according to my Z maintenance book I keep.
My new check valve came in today so I will be seeing how it performs on the car compared to the one I have currently. I suspect it will be identical, but we will see. I was walking the dog the other morning and a thought came to my mind. My brake pedal has great initial bite, but then goes hard as a rock, with no give in the pedal. I also recalled that while the car is in neutral, I cannot roll it. At all. Takes every ounce of strength to push it. When all parts were more 'fresh', I could push it up and down the garage with relative ease with one hand. Just to further flush this out, I am jacked up both sides by the diff adn wanted to see if I could spin the rear tires with the car in neutral. NADA. Drums are darn near seizing up the rear end. How long has this been going on? Not sure, I drove it around town about a month ago. No issues, but again, car did not want to roll without engine help. I now suspect something is amiss with the wheel cylinders / emergency brake adjustment. Perhaps a complete brake overhaul is not needed. Maybe just a refresh of the rear and some better pads would do on all four corners. I think rear disks would be a worthy upgrade. Anybody running around with just a rear disk brake swap.
A social media post caught my eye last week. Facebook Z forum. Some guy had put a Honda Accord electric booster on his Z. I have tried to get more information without success. This is interesting because it doesn’t depend on engine vacuum. With the proliferation of alternator swapping, the extra electrons wouldn’t seem to be a problem.
What are your thoughts?
