The gas in my tank is probably ~6 months old at this point and the car had been sitting for around 2 months (without fuel stabilizer in the tank) while I am redoing its interior.
I was traveling a lot for work and when I returned and tried to start the car, the battery was dead. After charging it, I found that the car wasn't starting and traced it to the fuel pump. After a lot of poking and prodding with the test light I found that the wires to and from the pump were getting pretty hot so I gave the pump a few smacks with a hammer, as some orange gas was starting to sneak its way out around the hose (not a great color for gas), and it started right up and I let it idle for ~20 minutes while I added fuel stabilizer.
Question - the car ran great, do I need to dump the tank? Should I replace the fuel pump if it's working now (its only about a year old)? did the pump somehow rust shut internally (the tank is around 3/4 full with 93 octane fuel which probably has ethanol in it).
Edited by chaseincats
https://www.classiczcars.com/forums/topic/69552-fuel-pump-hammer-smack/
I just got my '71 240Z back on the road last week after it sat for too long - longer than your car did. It wouldn't start for me so I had it trailered to a mechanic. He put in a new battery (Old one wouldn't hold charge, replaced under warranty), cleaned the carbs, drained the tank, and put in five gallons of fresh gas. When I picked it up it was a little hard starting and rough running until warmed up. His advice was to run it every day. After three days it starts easily and runs smoothly. It has a 20 year old electric fuel pump that continues to pump well.
I'm guessing your pump is OK. But I'd drain the tank and work with fresh gas.
Edited by psdenno
3 hours ago, Patcon said:
Modern fuel goes bad quickly, by design...
You could:
Drain it
Dilute it
or get it running and run it out, then add fresh
so far its running and ive been doing just that. thoughts on what clogged the fuel pump even though there was an in-line fuel filter between the tank and pump?
I had a knee replacement last November and didn't touch either one of mine until a week ago. I had to tap my carbs with a hammer to unstick the floats after hooking it up to a gas jug with new 93 octane and let it run straight from the jug to the fuel pump. It spit and sputtered, smelt like she-it but only for a few minutes.
I followed Phillips recommendations on removing the tank, so read over the first of his "tips and tricks" to drain that fuel out.
https://atlanticz.ca/zclub/techtips/fuel/gastank/index.htm
Were they stuck with gelatinated gas or internal rust?
I suspect the pump was fouled by crystalized fuel. Could be rust but I doubt it. Unless it's a cheap pump. Most internals in fuel pumps are aluminum or coated in some fashion.
Gotcha - so me knocking it loose in that case sent it to the engine, was caught by the fuel filter in the engine bay, and the car now runs great since that blockage is gone is what it sounds like?
Could it be a Lucas fuel pump?
14 minutes ago, Yarb said:
Do you have a pre-filter before the pump as well?
Ya - I had one of those clear paper filters that everyone has.
fuel pump
filter
I think that the common high pressure electric fuel pump uses steel rollers in a steel cage. I took an old one apart once. There are other designs.
The old Z fuel systems are pretty leaky. They let moist air in to the tank. The gas filler cap vacuum relief seals are usually shot. Wouldn't be a surpise if you had condensed water n the tank and the gasoline has dissolved water in it. Gas will hold some water, especially ethanol-containing fuel. If you don't want to drain the tank it might be worthwhile to use some HEET or other dewatering agent.
https://www.goldeagle.com/product/iso-heet-fuel-line-antifreeze-injector-cleaner/
