Posted Friday at 11:38 PM1 day comment_677568 Hey GentsI'm getting my Z engine restored update the cam to a more aggressive profile (regrind)The engines is pretty much done but I do need custom lash pads for this cam. My machinist has had issues with the flat bottom type lash pads and would prefer the stock type ones (the one with the little dimple on the bottom). Anyone know of a good vendor? I've used Lspecdatsun before, but the machinist is having issues getting what he needs. Thank you RegardsJan Edited Friday at 11:44 PM1 day by Pomorza Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/ Share on other sites More sharing options...
Yesterday at 12:29 AM1 day comment_677569 DatsunSpirit has lash pads…… Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677569 Share on other sites More sharing options...
22 hours ago22 hr Author comment_677570 5 hours ago, Diseazd said:DatsunSpirit has lash pads……Sadly not the ones I need. Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677570 Share on other sites More sharing options...
21 hours ago21 hr comment_677571 https://www.precisionshims.com.au/products/slotted Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677571 Share on other sites More sharing options...
11 hours ago11 hr comment_677575 17 hours ago, Pomorza said:My machinist has had issues with the flat bottom type lash pads and would prefer the stock type ones (the one with the little dimple on the bottom).Like these? What kind of problems has your machinist had with the flat bottomed pads? Not sure that the dimpled ones are actually "stock type" for an L28. Don't know.https://jdm-car-parts.com/products/kameari-performance-valve-lash-pads-for-nissan-l-enginehttps://datnissparts.com/stock-thickness-120-lash-pads-datsun-nissan-l4-l6-l16-l18-l20a-l20b-l24-l26-l28-13218-y7000/ Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677575 Share on other sites More sharing options...
10 hours ago10 hr comment_677577 I think the flat bottom ones are for grinding down? They sent me .190 with my cam kit. I thinks that's a little thick and they say it's all they have. Won't know for sure until I use them so...probably never. 🤣🤣 Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677577 Share on other sites More sharing options...
10 hours ago10 hr comment_677582 Here's some stuff. Not sure if they're showing the -Y7000 pads (Replaced By:) or the original part number.https://www.carpartsmanual.com/datsun/Z-1969-1978/engine-280z/camshaft-valve-mechanism/25https://www.nissanpartsdeal.com/parts/nissan-valve-guide~13218-a3501.html Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677582 Share on other sites More sharing options...
10 hours ago10 hr comment_677583 Also should note that it's called several different things around the internet. Valve guide, Guide - Rocker Valve, lash pad. Might help for searching. The part number works well though. Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677583 Share on other sites More sharing options...
9 hours ago9 hr comment_677585 12 hours ago, jonbill said:https://www.precisionshims.com.au/products/slotted@jonbill Where have you been friend? Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677585 Share on other sites More sharing options...
9 hours ago9 hr comment_677586 The smart ones hide, sit back and chill. That's why I'm on here everyday, trying to learn something. 😁Bugging the $^!# out of everybody... Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677586 Share on other sites More sharing options...
8 hours ago8 hr comment_677588 1 hour ago, Yarb said:@jonbill Where have you been friend?Oh I'm here every day, taking it all in 😄 Link to comment https://www.classiczcars.com/forums/topic/69472-custom-lashpads/#findComment-677588 Share on other sites More sharing options...
