Hi gents
I'm redoing the wiring harness in my Z and hope someone could help. I've come across these wires - which used to connect to the ECU. Here's what I know
Green -> goes to the fuel pump
Red/White -> 12V from the battery
The two that I don't know are the black/white and black/yellow.
From this diagram it looks like the black/yellow goes to the ignition switch among other place and the white goes to the ignition relay and the "IG" part of the fuse box. So would these be 12V switched? I am a bit confused. I've attached photos of the wires themselves as well as the part of the diagram where they are. Any help would be wonderful!
Thank you
Jan
Edited by Pomorza
https://www.classiczcars.com/forums/topic/69339-wire-identification/
11 minutes ago, Pomorza said:
Hi gents
Thank you
Jan
Black/yellow - 12VDC switched from key in START.
Black/white - 12VDC switched from ignition relay. The ignition relay coil is energized by the key in ON.
Hi Jan, You mention a ECU.. but a 280z has a ECCS.. looks like a ECU. but it's a analog computer.
Only the latest 280zx has a ECU, which deals with digital signals. AND most important has a microcomputerchip on board.
A analog computer has a lot of analog input signals and "computes" this to a final signal for the different inputs like the cold engine start injector as an example.
There are times to be pedantic. This isn't one.
Actually, the the ECCS was introduced with the 280ZX's. The ECU is used in both but started with the 280Z's. Generally, ECU stands for Electronic Control Unit or EFI contol unit. Edit - not sure what ECCS stands for.
Of course, it's all translated from Japanese, so the words might not make the most sense in English. But that's how ECU and ECCS are used in the FSM.
From the 1982 FSM, below. Might be the the ECCS "computer" should actually be called the ECCSU. There have been some discussions about what should be called a computer. I don't think that either of these actually do any number crunching.
Edited by Zed Head
I'm just going off what here.
They call it an ECU. My FSM calls it a "control unit". Either way, the analog wizardry box that makes the engine go vroom.
Don't forget the "black box" or the "voodoo" part.
"Dr. Bosch's Black Box of Analog Voodoo and Wizardry".
That's what makes the engine go vroom.
* "DBBBOVAW"
ECCS was first used on the 430-series Nissan Cedric in Japan (June 1979). ECCS stands for Electronic Concentrated (Engine) Control System.
Electronically-controlled (via an ECU) injection was introduced on a 230-Series Nissan Cedric 'EL' model at the 1970 Tokyo Motor Show:
Nissan was actively using a system ECGI (Electronic Controlled Gas Injection) back in 1971. Nissan group affiliate Diesel Kiki licensed the Bosch D-Jetronic system patents and re-engineered it to use with double and triple sidedraught throttle bodies on competition cars:
