1975 280z Build - Page 7 - Build Threads - Classic Z Car Club Skip to content
1975 280z Build
S30.World I wouldn’t give it another thought. Many folks on this site have purchased tanks from them including myself and were very satisfied.
Submerge the sending unit in CLR (calcium, lime, and rust) for 24 - 48 hrs. It will come out clean and usable.
You can also bench test it before you reinstall it. Quite a few articles here on the site referencing that.
I've done two tanks and it's not hard. You have to get everything together and plan it out as things have to be done pretty quick. 10 years ago it was $50 for all the chemicals. The only thing is letting it cure for about a month, most important. So if your in hurry to get on the road buy a new one. If not clean and coat it yourself.
A gallon of acid, $5, couple boxes of baking soda, $5, gallon of acetone $10, quart of red-kote $30. Plenty of empty 5 gallon buckets and a leaf blower.
240z (barely) runs very unevenly! - Page 2 - Help Me !! - Classic Zcar  Community
What would you say the success rate is. I’ve seen both results reported here. The overall condition of the tank is probably going to be the deciding factor. I had my tank redone at a shop, keep in mind you’re at their mercy as far as the job you get. At the end of the day my tank began to leak from minuscule rust pit holes. That’s when I decided to purchase a new tank. Again it’s all about what shape your tank is in and you really won’t know until you remove it.
Mine were more crud from leaving old gas in them for too long. The tanks were good and solid after I pressure washed the outside of them. That muriatic acid made the inside like new but after sloshing around for 5 minutes I had to pour in about 3 gallons of mixed ahead of time baking soda and water to neutralize the acid then emptied that into an empty 5 and killed a lot of ant beds around my property. Then the acetone to remove the water, quick hit with the leaf blower and then the Red-Kote. Sloshed that around completely covering the tank and let that drain out into another 5 then direct sunlight for 30 minutes, then another round with the leaf blower. Then I put that bitch on a shelf and got drunk. It was very nerve wracking for this 'ol boy, but when all was said and done I was and still am proud of what I did. You see, I hate following directions. beer
Edited by siteunseen
2 hours ago, siteunseen said:
I borrowed ideas from these two guys and added a few of my own from past motorcycle tank plus the instructions from Red-Kote.
https://atlanticz.ca/zclub/techtips/fuel/gastank/index.htm
https://woodworkerb.com/home/datsun-240z-rebuild/240z-fuel-tank/
https://www.damonq.com/techsheets/red-kote.pdf
These are gold!! Thank you!
I had considered trying to clean it myself, but i am in an apartment building for now and I'm not really keen on using that stuff and leaving it unventilated. Besides, I'm pretty sure I'm going to have to get the wheel well replaced before I can put the tank back in. I don't think there is enough metal left in that area to support it for long. I'm not far from Denver so there are a few restoration shops around and I'm sure they will have a better idea if its salvageable or not.
I have used an epoxy product from Caswell to coat a tank. It's very thick and would deal with pinholes pretty well. I suspect that tank will have quite a few pinholes once it's properly cleaned. It might be hard to do in an apartment setting...
worked on the fuel system and a couple other little things today. The phillips screw stripped out so I had to drill the heads. Once I had the pump removed I had plenty of thread left over to pull them out with vice grips. I feel like this is the original pump since it had the goop on the terminals, however, I'm not sure why the wires were cut and just twisted together. Maybe an old replacement pump came this way.
I'm having trouble identifying this part. I'm dont think its a fuel pressure regulator. I know there is one on top of the engine.
The new pump doesnt have the outlet on the side, but it does come with a brake line style fitting.. Overall it just ends up longer. It will still fit in the bracket but I think I will look for a one piece elbow when I go to the hardware store for new screws.
The part number on the box is E16078, it appears to be an O'reillys part and it appears to be correct for the vehicle. Rock auto also shows a carter pump that is identical.
Has anyone put one of those cheap clear fuel filters after the fuel pump? I'd like to have one up in the engine as a prefilter for the OEM filter. I dont have a good way to clean out the hard lines and I would like to see if there is any crude in there I need to worry about.
That's the fuel damper. It absorbs pressure pulses, from one end or the other. Not much to it and they seem to survive without problems.
Don't forget that pressure after the pump is at least 36.3 psi. Those small plastic filters aren't rated for that.
I made a loop in my fuel line after the pump to solve that sharp bend problem.
The original pump includes an inlet strainer, but I don’t think the O’Reilly’s E16078 has one. In principle it’s the same style as the Bosch 0580 254 044 that replaced the factory unit.
If you want to add a pre-filter, you can install two 5/16" filters in parallel to avoid fuel starvation and prevent cavitation in the pump. Their only purpose is to protect the pump, the filter up front will protect the injectors.
280 Series Fuel pump Alternatives Rev 1.pdf
