Maybe this will help. My car is a 71 z.
Lower left green wire is for turn signal which is R/W in the harness
Lower right wire is reverse which is R/B in the harness
Upper green is tail light all blacks are ground. Which is G/W in the harness.
The other light is brake. However I installed another 1157 socket So I would have both of the top lights tail lights and brake lights. I also installed led bulbs.
  • 2 years later...
48 minutes ago, Patcon said:
Can anyone post up a JDM or Euro version of the wiring diagram for the tail lights to identify wire colors? @kats @jonbill @HS30-H
The 72 FSM has the colors.
In @kats connector it does not show a Br or BrW wire. It shows two GW.
This may be the correct orientation:
Edited by SteveJ
So factory operation of the JDM tail light??
Reverse is reverse
Turn signal is turn signal and flashers
Both upper red lamps are parking lights?
Only one upper red lamp is brake light? Maybe the outboard one?
No, the Japanese market parking light system has its own bulb in each rear lamp unit. It's the one that is otherwise blanked off with the 'P' plug/grommet in the centre of the lamp unit.
Am I dreaming or do I remember correctly that someone somewhere had created a plug-in pigtail that 'converted' our US based wiring to the JDM for use with the JDM lens? The purpose of the pigtail is to prevent from having to cut into the factory wire harness.
Edited by texasz
This maybe?
