September 11, 20222 yr comment_645219 Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645219 Share on other sites More sharing options...
September 11, 20222 yr comment_645220 Maybe this will help. My car is a 71 z. Lower left green wire is for turn signal which is R/W in the harness Lower right wire is reverse which is R/B in the harness Upper green is tail light all blacks are ground. Which is G/W in the harness. The other light is brake. However I installed another 1157 socket So I would have both of the top lights tail lights and brake lights. I also installed led bulbs. Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645220 Share on other sites More sharing options...
September 16, 20222 yr comment_645457 Hi Patcon , here are some Fairlady Z series’s wiring , hope it helps you a bit . Kats Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645457 Share on other sites More sharing options...
September 16, 20222 yr Author comment_645484 Thanks Kats Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645484 Share on other sites More sharing options...
Yesterday at 12:51 AM1 day Author comment_676968 Can anyone post up a JDM or Euro version of the wiring diagram for the tail lights to identify wire colors? @kats @jonbill @HS30-H Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-676968 Share on other sites More sharing options...
Yesterday at 01:53 AM1 day comment_676969 48 minutes ago, Patcon said:Can anyone post up a JDM or Euro version of the wiring diagram for the tail lights to identify wire colors? @kats @jonbill @HS30-HThe 72 FSM has the colors.In @kats connector it does not show a Br or BrW wire. It shows two GW.This may be the correct orientation: Edited yesterday at 01:54 AM1 day by SteveJ Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-676969 Share on other sites More sharing options...
23 hours ago23 hr Author comment_677008 So factory operation of the JDM tail light??Reverse is reverseTurn signal is turn signal and flashersBoth upper red lamps are parking lights?Only one upper red lamp is brake light? Maybe the outboard one? Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-677008 Share on other sites More sharing options...
13 hours ago13 hr comment_677031 9 hours ago, Patcon said:Both upper red lamps are parking lights?No, the Japanese market parking light system has its own bulb in each rear lamp unit. It's the one that is otherwise blanked off with the 'P' plug/grommet in the centre of the lamp unit. Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-677031 Share on other sites More sharing options...
13 hours ago13 hr comment_677032 9 hours ago, Patcon said:Only one upper red lamp is brake light? Maybe the outboard one?Both upper reds operate as side lights and brake lights. Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-677032 Share on other sites More sharing options...
6 hours ago6 hr comment_677038 Am I dreaming or do I remember correctly that someone somewhere had created a plug-in pigtail that 'converted' our US based wiring to the JDM for use with the JDM lens? The purpose of the pigtail is to prevent from having to cut into the factory wire harness. Edited 6 hours ago6 hr by texasz Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-677038 Share on other sites More sharing options...
6 hours ago6 hr comment_677039 I bought mine from Futofab.com and they were plug-up and go. No changes on my end. Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-677039 Share on other sites More sharing options...
6 hours ago6 hr comment_677040 15 minutes ago, texasz said:Am I dreaming or do I remember correctly that someone somewhere had created a plug-in pigtail that 'converted' our US based wiring to the JDM for use with the JDM lens? The purpose of the pigtail is to prevent from having to cut into the factory wire harness.This maybe? Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-677040 Share on other sites More sharing options...
