September 11, 20222 yr comment_645219 Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645219 Share on other sites More sharing options...
September 11, 20222 yr comment_645220 Maybe this will help. My car is a 71 z. Lower left green wire is for turn signal which is R/W in the harness Lower right wire is reverse which is R/B in the harness Upper green is tail light all blacks are ground. Which is G/W in the harness. The other light is brake. However I installed another 1157 socket So I would have both of the top lights tail lights and brake lights. I also installed led bulbs. Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645220 Share on other sites More sharing options...
September 16, 20222 yr comment_645457 Hi Patcon , here are some Fairlady Z series’s wiring , hope it helps you a bit . Kats Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645457 Share on other sites More sharing options...
September 16, 20222 yr Author comment_645484 Thanks Kats Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-645484 Share on other sites More sharing options...
5 hours ago5 hr Author comment_676968 Can anyone post up a JDM or Euro version of the wiring diagram for the tail lights to identify wire colors? @kats @jonbill @HS30-H Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-676968 Share on other sites More sharing options...
4 hours ago4 hr comment_676969 48 minutes ago, Patcon said:Can anyone post up a JDM or Euro version of the wiring diagram for the tail lights to identify wire colors? @kats @jonbill @HS30-HThe 72 FSM has the colors.In @kats connector it does not show a Br or BrW wire. It shows two GW.This may be the correct orientation: Edited 4 hours ago4 hr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/67828-euro-jdm-taillight-wiring/?&page=2#findComment-676969 Share on other sites More sharing options...
