Posted May 12, 20223 yr comment_640308 After finally getting my car on the road and logging about 100 miles this week, I’m considering going a different direction with my steering wheel. I don’t really want to go aftermarket but I can be convinced otherwise. Right now I have a nicely restored 240z “wood” composite steering wheel. It looks awesome. Here is what I don’t like. The grip diameter is small and a bit slippery. I know this was how they’re supposed fo be. I think 14” would be better, and I like leather feel. I also think it’s a little too big in overall diameter at 15”. So doing my research I see a few options and keep in mind that I don’t have the skills or fancy tools like Captain Obvious who probably installed airbags in his Z32 steering wheel modification. Options: 1. Have my stock 280Z wheels sent off for refurbishment and wrapped in leather - quote was $360 2. Buy an aftermarket one like MSAs or a Momo type, (my least favorite option) ~ $260 3. Buy the Zcardepot competition wheel that looks stock but just about an inch smaller (leaning this direction) 4. One I haven’t discovered Finally, I have three 240z composite steering wheels. Not the series one with open holes in spokes. I’d be will to make a trade for someone in the market for one of these. - one is totally restored and looks new -one is original but in great condition (bought it from a z collector in Montana on a work trip) -one needs restoration (pulled from salvage yard) see pics Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/ Share on other sites More sharing options...
May 12, 20223 yr comment_640315 The 280Z steering wheels I have are covered in leather, and the rim cross section is about twice the diameter of the faux wood wheels that came on the 240Z. Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640315 Share on other sites More sharing options...
May 12, 20223 yr Popular Post comment_640322 I really like my 240's wheel over the 280's. It gives a twitchy feedback which I like. It's like driving on a rail. Those new wheels that are straight on the bottom are interesting. I suppose you'd get more leg room but I steer with my legs a lot. Beer, phone and shifting is a lot to do. Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640322 Share on other sites More sharing options...
May 12, 20223 yr comment_640323 i wanted a really fat wheel for my aging arthritic fingers. I cut down to the metal core, then encased in successively larger layers of heater hose, and finally wrapped in a custom Wheelskin. Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640323 Share on other sites More sharing options...
May 13, 20223 yr comment_640335 I put the "wood" steering wheel on my 260z but it was too thin for my tastes. I purchased an old Nissan wheel with heavily deteriorated foam covering and made a black walnut steering wheel out of it. Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640335 Share on other sites More sharing options...
May 13, 20223 yr Author comment_640336 I put the "wood" steering wheel on my 260z but it was too thin for my tastes. I purchased an old Nissan wheel with heavily deteriorated foam covering and made a black walnut steering wheel out of it. Wow…way outside my skill level. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640336 Share on other sites More sharing options...
May 13, 20223 yr Author comment_640337 i wanted a really fat wheel for my aging arthritic fingers. I cut down to the metal core, then encased in successively larger layers of heater hose, and finally wrapped in a custom Wheelskin. Shak hands. You must have played for the NBA in another life Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640337 Share on other sites More sharing options...
May 13, 20223 yr comment_640338 Ferg, I refurbed a 240Z steering wheel because I liked the way it looks. But like you, I don’t care much for how thin it is. I bought a “Compe” wheel from a guy in Japan (I’m guessing it’s the same as what ZCarDepot sells) and like it way more. It looks good, the horn works, and I have not found it necessary to bend the turn signal lever to keep from accidentally hitting it while driving. Sent from my iPad using Tapatalk Pro Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640338 Share on other sites More sharing options...
May 13, 20223 yr comment_640339 5 hours ago, Jeff Berk said: I put the "wood" me too... I see that you made it exactly like me! ( in 2007) was i your inspiration or...? exactly same system, 6 on front parts and 6 on the rear, i made the front parts over the steel inner ring.. the rear parts are massive. (mahogany wood) I also did this because of my big hands.. i had no fun with the tiny orig. 240z wheel.. (iirc, i had this "making of a steeringwheel"explaned somewhere on this site i believe.. 🤔 Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640339 Share on other sites More sharing options...
May 13, 20223 yr Author comment_640340 5 hours ago, pogden said: Ferg, I refurbed a 240Z steering wheel because I liked the way it looks. But like you, I don’t care much for how thin it is. I bought a “Compe” wheel from a guy in Japan (I’m guessing it’s the same as what ZCarDepot sells) and like it way more. It looks good, the horn works, and I have not found it necessary to bend the turn signal lever to keep from accidentally hitting it while driving. Sent from my iPad using Tapatalk Pro Thanks, the only issue I have is I think those competitions wheels aren’t leather covered, they’re the rubber I think. Is yours rubber and do you like that feel? Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640340 Share on other sites More sharing options...
May 13, 20223 yr comment_640345 13 hours ago, Jeff Berk said: I put the "wood" steering wheel on my 260z but it was too thin for my tastes. I purchased an old Nissan wheel with heavily deteriorated foam covering and made a black walnut steering wheel out of it. There is a guy on Ratsun, who lives in Texas, that has made a few wood rims for steering wheels. It is a fairly straightforward process. Make a circular jig for a router, select a nice cut of wood, rout the two halves, glue them onto the rim, and finish the wood. One he laminated several different types of wood stained different colors. It looks awesome. He even made a matching shift knob. Check it out here: https://ratsun.net/topic/78921-diy-steering-wheels/#comment-1700673 Edited May 13, 20223 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640345 Share on other sites More sharing options...
May 14, 20223 yr comment_640375 20 hours ago, Racer X said: glue them onto the rim, Use 2 component glue between the steel and the wood.. and .. use some professional wood glue between the wood. think that's the best way. 20 hours ago, Racer X said: He even made a matching shift knob. That's what i did TO!! (Also out of mahogany!) (They are in my 240z now for 15 years and working perfect.) Link to comment https://www.classiczcars.com/forums/topic/67474-280z-steering-wheel/#findComment-640375 Share on other sites More sharing options...
