8 hours ago, gundee said:
Finally getting rid of the stock exhaust manifold.
This header is going to mate to the existing 2-1/2" exhaust pipes.
Going very well so far.
Intake is now on. Those bottom nuts were a sob to get a socket or wrench on to tighten.
Did you notice the billet steering rack clamps?
My Sept 70 parts car arrived today. Sadly it only had two front wheels on as rear suspension pulled apart when putting on flatbed. Grrrr.
Anyway all is well. Back end is gone but a lot of interesting parts:
BRE Spook
Rear hatch with vents
Dash with radio and 140psi gauge
Excellent Centre console
Grill
Badges
I need to figure out how to get the hood off to see head and front end (which I need)
It also came with ZFinding floor pans and BadDog Rails in boxes ?
BRE Spook
Grill
Badges
Pictures!!
Got the parking brakes adjusted. The Silvermine cable is a little longer than stock so I had to adjust the linkage a bit.
Connected the rear brake lines and bolted the calipers down.
Adjusted the rear camber settings on the top of the CX Racing coil overs to let the big meaty 225/60R16 tire’s get under the wells.
Still needs a little adjusting but the Techno Toy Tuning rear lower control arms are phenomenal for adjustments!
Next up is the front brake lines and some small adjustments there before I drop the car on the ground. I’ll probably fill the diff while it’s still in the air too.
After:
My lucky Day..
  • clear windshield
  • early hood with no corner reinforcements
  • early gauges
  • early radio
  • early mirror
  • early alternator
  • early hatch with vertical wires and vents (uncracked)
  • one storage door
  • grill in great shape
  • Bumpers in great shape
  • Side and window glass in great shape
  • 2 sets of 4 screw carbs
  • mostly uncracked plastic panels
  • perfect center console
  • perfect headliner and vinyl trim
  • early 710 oil cap
  • E31 head
Notable items:
  • Engine and transmission was swapped
  • no differential
  • lots of rust
  • steering wheel was swapped
  • seats were recovered
  • COIL OVERS!
  • Pulling off flatbed distorted rear but the bumper is fine... whew
THIS IS A BIG PICTURE!
Edited by 240260280
1 hour ago, 240260280 said:
After:
My lucky Day..
  • clear windshield
  • early gauges
  • early radio
  • early mirror
  • early alternator
  • one storage door
  • early 710 oil cap
  • E31 head
Notable items:
  • no differential
  • lots of rust
  • COIL OVERS!
Early gas cap too. Those are pretty rare also...
46 minutes ago, 240260280 said:
I'll have to do the @jfa.series1 spook repair ?
Easy peasy!  Great find on a parts car - I'm seriously jealous.
