Skip to content
plastic vs steel fan
I am restoring HLS3028726, build date April 1971.  Is the steel fan or the plastic correct for this car?
Second question; what is the correct finish for unpainted bolts; cadmium, tin, nickle, or ???
Thanks,
RDM
I don't know on the fan. I suspect metal was original but plastic is safer
On the bolts most are yellow zinc but not all. Some are bright zinc like the door strike bolts and screws and the hatch screws.
The member here with the user name "careless" has meticulously done a car and has good documentation in his thread. Look through it. It will answer a lot of your questions
My Z is also an April '71 build and it came with a metal fan which went through the radiator around 1979 when the water pump failed.  I replaced it with a lighter weight metal flex fan and no clutch at the time, but now have a plastic fan and clutch
Dennis.
The steel fan was used up to July/71
http://www.carpartsmanual.com/datsun/Z-1969-1978/engine-240z-260z/water-pump-fan
My 7/70 had the steel fan and I had exactly the same problem as Dennis in the early 80's.  I now have a plastic fan from a 280.
Edited by CanTechZ
Thanks guys,
I take it that the consensus opinion is "forget about 'original' - save the car and run with the plastic fan."
Plastic it is!
With the fan issue settled, your second question is about the finish on the various fasteners and clamps.  A general "rule of thumb" is that everything forward of the firewall has a yellow zinc or cadmium finish, everything aft of the firewall is white/clear zinc.  One exception to this is the fuel  cap, collar, and screws are all done in yellow zinc / cadmium.  I think the early cars (perhaps all) had clear zinc finish on the OE hose clamps.  I did all my OE hose clamps in yellow zinc for consistency under the hood.  Also, the fuel rail is yellow zinc / cadmium.
'Forward of the firewall = yellow zinc'...  What about the coil mounting bracket?  The three that I have are all clear zinc.
Sorry.  Double post.
Edited by Namerow
double-post
Which is why I hedged my statement as a general rule of thumb.  I can't confirm the color of the coil bracket.  Another couple of examples are the  fuel filter bracket and the brake vac check valve clamp on the firewall - both finished in black.  Someone with a pure stock car such as AZ-240 would have to chime in with specifics if our OP wants to go with that level of detail.
