July 15, 20178 yr comment_525771 Nice! Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-525771 Share on other sites More sharing options...
July 16, 20178 yr Author comment_525827 11 hours ago, wheee! said: Nice! thank you!! i am down to (not necessarily in this order) it has been a long almost 2 years bumpers front strut brace insurance (monday) tags (monday or tuesday) test drive (after tags) . Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-525827 Share on other sites More sharing options...
July 16, 20177 yr comment_525860 Great to see progress! Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-525860 Share on other sites More sharing options...
July 17, 20177 yr comment_525903 Thanks for the delicious pics. So much incentive for me to push ahead too! Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-525903 Share on other sites More sharing options...
July 21, 20177 yr comment_526267 Maybe a little late Sweats but the upper rear corner of the door seal needs to have a "vee" cut into it. This allows the rubber to go all the way back into the corner and meet to seal it. That corner will allow water to come in that you want notice until you begin getting that moldy smell inside. A moldy smell means rust is not far behind it. Sorry I didn't get a chance to offer it earlier. Not too late to fix it though. Looks good. We need more motion video though. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526267 Share on other sites More sharing options...
July 22, 20177 yr Author comment_526299 excellent day today, cherry popped! the pig got a bath and 8 miles on the odometer. the suspension is very nice and tight, throttle response is good, but the brake prop valve needs a little tuning. going to do a few more miles tomorrow, get some fuel and then sunday plug in the tracking software for the a/f ratio meter. kind of hard to watch the meter and drive at the same time Edited July 22, 20177 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526299 Share on other sites More sharing options...
July 22, 20177 yr comment_526305 Congrats!!!!! Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526305 Share on other sites More sharing options...
July 22, 20177 yr comment_526311 Beautiful work Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526311 Share on other sites More sharing options...
July 22, 20177 yr comment_526313 You've managed to achieve a really nice stance for the car. The match-up of tire size/profile to wheel diameter/offset relative to the wheel openings looks spot-on. I really like those wheels, too. A refreshing change from Panasports. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526313 Share on other sites More sharing options...
July 22, 20177 yr Author comment_526336 just went into town to fill the tank and did another 35 miles. this pig pulls hard and nice. a/f mix is in the mid to high 13's on a hard 2nd-3rd pull, cruises in the low 14's. seems to have a weak spot right off idle, (a/f mix 15-16) no bog, but just noticeable. needs a front end alignment and the exhaust piping tweaked a bit and welded. it sounds SWEET! no tire rub as of yet. i was a little worried about that. overall, im very happy Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526336 Share on other sites More sharing options...
July 22, 20177 yr comment_526338 IMHO, A weak spot just off idle is the nature of the beast unless it's so weak that it's a PITA. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526338 Share on other sites More sharing options...
July 22, 20177 yr comment_526349 2 hours ago, sweatybetty said: just went into town to fill the tank and did another 35 miles. this pig pulls hard and nice. a/f mix is in the mid to high 13's on a hard 2nd-3rd pull, cruises in the low 14's. seems to have a weak spot right off idle, (a/f mix 15-16) no bog, but just noticeable. needs a front end alignment and the exhaust piping tweaked a bit and welded. it sounds SWEET! no tire rub as of yet. i was a little worried about that. overall, im very happy Gorgeous restoration! Are you going to add a front stabilizer bar like this pic? What are your thoughts? Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=28#findComment-526349 Share on other sites More sharing options...
