Looks like a "throttle shaft"
This might be a good resource for you:  http://www.ztherapy.com   Check out the spotters guides
* updated link.
post-22465-0-94575700-1444339155_thumb.j
Edited by Kurbycar32
This might be a good resource for you:  http://www.ztherapy.com/technical_stuff/spotterguides/zcar/240spotter.htm
That link gives a 404 error.
Throttle shaft for sure. If it is unusable because of wear, the carb body that it came from will also be worn. ZT machines the body & uses sealed throttle shaft bearings. Better than new.
Thanks for all the great info fellas ! The carbs that came with car were in a box completely disassembled so I don't know if this throttle shaft went with those carbs. That shaft doesn't fit into the body I have. I will be talking with ZT though.
Mark M- you're in PDX too ? Maybe someday, if you have time, we can meet up and you can go over my car with me ??
907Series1Z
 Absolutely. The chance to spend time with another Z owner is always a treat. BTW I have three ea. 4 screw SUs that are not being used. 1 front & 2 rears. We need to talk. I'll PM you.
 Mark
Man, have not posted in a while, but yup throttle shaft as stated above.  And yup, Z therapy are miracle workers with these parts.
Make SU's sing again.
