Mark Maras Posted May 29, 2015 Share #205 Posted May 29, 2015 Soo glad I was wrong. Good job finding it. I likely would have started tearing things apart only to confirm nothing was wrong & have to keep searching. Link to comment Share on other sites More sharing options...
EuroDat Posted May 29, 2015 Share #206 Posted May 29, 2015 I bet you feel like superman after finding a simple fix to what looked like an enormous problem. Good start to the weekend. Link to comment Share on other sites More sharing options...
oranngetang Posted May 29, 2015 Share #207 Posted May 29, 2015 I feel like this is thr kind of problem I seem to have over and over. Simple fixes that appear to be larger than they are, and therefore immensely stressful. Cheers again for the starter advice, that gear reduction model is nothing short of insane. Link to comment Share on other sites More sharing options...
Kurbycar32 Posted July 7, 2015 Author Share #208 Posted July 7, 2015 The motor lives! Setting the timing was a pain. the motor does not have a timing marker with various degrees listed, its just a pointer and a mark on the crank at TDC. I called up Rebello and got some helpful advice on getting the motor running. After purchasing a super bad arse timing light (Innova 5568) that would allow me to adjust the timing flash to a specific degree of timing everything got easy. In addition to dialing in my timing preferences the light also has a tach, voltmeter and measures dwell. Essentially i left the light plugged in while using my carb flow meters so i had real time feedback on what the engine was doing while balancing the carbs out. This motor is rev happy! Next up is finalizing everything, triple checking the installation and then a quick drive over to the exhaust shop since i literally blew up my muffler. Next on my list of tools is a wide band o2 meter. Oranngetang what model did you end up with? Link to comment Share on other sites More sharing options...
oranngetang Posted July 7, 2015 Share #209 Posted July 7, 2015 (edited) Innovate DLG-1. What is your idle timing and maximum timing advance? IE: -10* and -36*. 280zx dizzy or stock? I have the pertronix setup replacing my points, otherwise stock. I'd say this car is putting down 200hp at the wheels y butt dyno. I need to find a chassis dyno in the region that'll have time for tuning with a few needles. Youtubing DIY dyno building. Kidding... Edited July 7, 2015 by oranngetang Link to comment Share on other sites More sharing options...
Kurbycar32 Posted July 7, 2015 Author Share #210 Posted July 7, 2015 (edited) I was about to ask you the same. I havent done any excessive tuning but my idle timing looks like its -33* degrees, which seems crazy high to me. I am using the stock 260z dizzy which Dave said was going to work. I intend on upgrading the whole ignition system after this is a fully functional car again Edited July 7, 2015 by Kurbycar32 Link to comment Share on other sites More sharing options...
oranngetang Posted July 7, 2015 Share #211 Posted July 7, 2015 I need to verify. Couldn't find my digital light w advance when I set and Dave has 4 timing marks on my pulley I'm assuming are 0, 5, 10 and 15. He said to set base at 10 degrees and leave the vacuum advance disconnected on my engine. Couldn't give me a total advance number. Link to comment Share on other sites More sharing options...
oranngetang Posted July 7, 2015 Share #212 Posted July 7, 2015 I'm guessing if you're running at a base of -33 your mechanical advance is stuck on you. That seems excessive, as I believe I gain about 25 degrees from my mechanical swing. IIRC Link to comment Share on other sites More sharing options...
Kurbycar32 Posted July 7, 2015 Author Share #213 Posted July 7, 2015 The 260z distributor is electronic, do i have a mechanical advance? Link to comment Share on other sites More sharing options...
oranngetang Posted July 7, 2015 Share #214 Posted July 7, 2015 I honestly am not sure. Someone else will need to chime in on that assuming I have a '70. Link to comment Share on other sites More sharing options...
Captain Obvious Posted July 7, 2015 Share #215 Posted July 7, 2015 Yes. the stock 260 distributor has a vacuum controlled mechanical advance feature. Link to comment Share on other sites More sharing options...
oranngetang Posted July 12, 2015 Share #216 Posted July 12, 2015 28-32 advance from the mechanical on my 240 dizzy. If I start at 10, total bounces 28-32, though for some reason it's a sporadic reading, and the position of the inductive pickup seems to matter a lot... Link to comment Share on other sites More sharing options...
