Wiper pump motor thoughts - Open Discussions - Classic Z Car Club Skip to content
I’m getting a 1970 car back in shape. It has a lot of unoriginal parts but my general philosophy has been to restore closer to original condition where possible.
A PO clipped the wires in the engine bay that go to the pump motor. I removed the tank and pump and tested on bench. The motor spins but develops no suction. It is the original motor and tank for the 1970 car.
I’m not sure what to do at this point. The wipers work, the wiper fluid nozzles are ok (tested those too), but it seems I either get a new motor and put in the tank and thus lose some more originality or I leave it as is. I’m even if that tank pump worked I would never fill it. Water in the car???! No thanks. But otoh it’s kind of cool if everything works.
I see these new motors and replacement tank/motor combos for sale so people must be buying them.
What would you do if you were me?
I’m not planning on selling the car any time soon. And like I said it’s never going to be original enough to sell as anything other than a nice driver. (Err at least I hope it will be a driver in a month or two).
Ask around., I’m sure someone has an old pump motor laying around. Where are you located. It helps us if your profile is complete with the area of the country you live in.
The pump motor does not produce suction, it depends on a gravity feed of the washer fluid. Check the attachment of the supply and output tubes to see if they are correct. Ask me how I know!!! 😉
1 hour ago, Zed Head said:
Can you take it apart? Looks like it's possible. Might be worth an inspection. Can't hurt if it's already broken.
https://www.ebay.com/itm/257561741748?_skw=Datsun+240z+OEM+Factory+Windshield+Washer+Tank+Assembly+27470-89901
Can I take it apart? Yes. Put it back together again? We’ll see…
as soon as I got the top part off some plastic bits fell out. I would say those are what’s left of the impeller. Might work with a new one. In for a penny…
Edited by Warty
removed triple quotes.
Explains why somebody would be selling impellers. I was a little bit "what the heck" when I saw the eBay listing. 10 available. Probably one of those wrecking yard pocket harvesters.
6 minutes ago, Zed Head said:
I would have to cut up the rubber boot that holds the motor to the tank with that one. The power connector is too tall. I think I saw a replacement motor plus boot somewhere.
Trico 11-601 is the pump you’re looking for.
You can also use that pump that Zed Head showed, just chop off that plastic connector and solder the wires to the revealed terminals on the pump body.
Also https://www.classiczcars.com/forums/topic/63107-how-to-replace-windshield-washer-pump-motor/
Edited by zKars
Good lord, just searching around on the net for that part number shows prices in the $40-70 range! I don’t think so Tim!
Guess my stash of these is going to be my retirement suppliment.
