Probably a pretty elementary question for this learned forum, but for my 240Z, HLS3028726, which is the correct cylinder head , N42 or E31? I have two of the former and one of the latter.
Many thanks,
Richard
https://www.classiczcars.com/forums/topic/69524-240-cyl-heads/
Random aside that might be relevant - there is also an N42 from the Maxima L24's. Some people call them MN42's. They have a cylinder head temperature sensor hole tapped in below and between the 5 and 6 spark plug holes.
Still not correct for your car but could factor in to selling. Desirable for people looking to raise compression ratio on an L28.
Don't forget about the bronze valve seats that came OE in the E31. They're not good with the gas we use now but you can have them updated to steel for not much money if you're not currently running the head.
