I've heard some conflicting info on the subject, so I figured I'd consult the hive mind. Regarding the wire-type hose clamps used all over...
1) Were they all clear zinc/cad, all yellow zinc (zinc with yellow chromate), or are their two variants?
2) If two variants, what is the rule of thumb as to which ones go where?
3) If two variants, did they have different part numbers?
I ask because it was my understanding (perhaps incorrect) that they were all clear zinc, then I discovered this when disassembling my clutch master cylinder tonight:
Extra credit: Have any other data guru's out there put together a spreadsheet that lists all clamps and their sizes?
Thanks!
https://www.classiczcars.com/forums/topic/69358-hose-clamp-finishes/
I'm not sure when they changed the clamp style, but on the really early cars they used a different clamp style.
Does you think your master is original to the car?
Edited by Captain Obvious
OK, I was so focused on the finish color I totally missed the fact that the screw was a hex-head instead of a pan-head JIS! D'oh!
Captain, I really don't know the history of this car...so nothing surprises me.
But here's my basic question...now that I have all the small hardware cleaned and ready to send out for plating, should all my hose clamps go in the "clear zinc" box or the "yellow zinc" box?
Yes, I apologize... In true internet forum fashion, I got involved in the topic and never answered the question that was asked. And I also apologize that I do not know the answer.
I've heard that "everything in front of the firewall was yellow chromate, and everything behind the firewall was clear." Not sure if that's 100% correct, but it's more correct than not. So if that rule holds true, then your brake master clamps should be yellow.
Yeah, but that rule of thumb might be better said that "everything in the cabin is clear, otherwise yellow". Because most all the undercarriage is yellow. It seems like Nissan felt that if it is to be seen (without opening the hood), it should be silver-colored. Yellow, with it's additional chromate protection, seems to be mostly reserved for items out-of-sight of passengers.
But I'd still like additional opinions...what color(s) have you seen your original hose clamps? I mean both the engine compartment ones as well as the one back by the fuel evap tank.
So I took a close look at the $310K BAT Green Series 1 and was a bit surprised. In multiple places is looks like the hoops are yellow and the screw mechanism is clear. Am I imagining this?image.png
