Posted June 26, 20214 yr comment_624106 I have 2 steering wheels. I would like to get at least one refreshed like new. I dont think i have the skills to do that and make it look 100%. Any suggestions on who could do this? LIke should i call local carpenters? Â Â Â Edited June 26, 20214 yr by Wally Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/ Share on other sites More sharing options...
June 26, 20214 yr comment_624111 Actually it's not that hard to do. They're not real wood anyway 😉 Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-624111 Share on other sites More sharing options...
June 27, 20214 yr comment_624127 I think there is some wood in there, but put it this way... Nobody should worry about termites. Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-624127 Share on other sites More sharing options...
June 29, 20214 yr Author comment_624252 so gloss black on metal and an "wood" some lacquer i assume? Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-624252 Share on other sites More sharing options...
June 29, 20214 yr comment_624253 I used a satin black on the spokes I lightly sanded the rim and restained it then some spray can urethane Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-624253 Share on other sites More sharing options...
June 29, 20214 yr comment_624281 What he said. Â Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-624281 Share on other sites More sharing options...
June 29, 20214 yr comment_624284 The wheel rim is a type of resin that has wood fibers impregnated. A good way to clean it is a soapy solution in the kitchen sink and VERY GENTLY rub it down with a fine steel wool. You don't want to damage or remove the wood fibers. Strip the spokes and hub to bare metal and finish out as @Patcon mentioned. Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-624284 Share on other sites More sharing options...
July 27, 20213 yr comment_625787 @Wally There is a guy on Facebook that offers this as a service. Its not cheap, but the photos look good. Links below. https://www.facebook.com/Datsun-240Z-Steering-Wheels-100916391333259/ @Patcon @Captain Obvious Are there any common challenges or problem spots to look out for when refinishing? And does this faux wood refinish like real wood? Looking for a used wheel to put on my 280z, but 100% of the wheels I see up for sale need some TLC. Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-625787 Share on other sites More sharing options...
July 27, 20213 yr comment_625790 Its easy to over sand. Not exactly like wood but I found it stained out ok Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-625790 Share on other sites More sharing options...
July 27, 20213 yr Popular Post comment_625802 6 hours ago, Muzez said: And does this faux wood refinish like real wood? Here's a couple of close-up pics of my wheel in process some years ago, one with it stripped and one with it stained and topped with a coat of clear lacquer. The preferred clear coat today is usually spray polyurethane. I used a hand-rubbed oil base stain. Edited July 27, 20213 yr by jfa.series1 Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-625802 Share on other sites More sharing options...
July 29, 20213 yr comment_625892 Going to check out out this week. Is there anything to look out for with regards to the center gearing where the hub connects to the steering wheel? Or with the electrical for the horn? Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-625892 Share on other sites More sharing options...
July 29, 20213 yr Author comment_625900 On 7/27/2021 at 9:58 AM, Muzez said: @Wally There is a guy on Facebook that offers this as a service. Its not cheap, but the photos look good. Links below. https://www.facebook.com/Datsun-240Z-Steering-Wheels-100916391333259/ @Patcon @Captain Obvious Are there any common challenges or problem spots to look out for when refinishing? And does this faux wood refinish like real wood? Looking for a used wheel to put on my 280z, but 100% of the wheels I see up for sale need some TLC. i have message this person. no response as of yet. i will update with ETA's and price if he responds  Link to comment https://www.classiczcars.com/forums/topic/65542-steering-wheel-refreshing/#findComment-625900 Share on other sites More sharing options...
