April 26, 20196 yr comment_574237 Jeff, don’t know if you sourced the new wheel studs yet, but they are available at Silvermine motors. I just ordered a set myself! Edit: NVM, I see you drilled out the rotors... Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-574237 Share on other sites More sharing options...
May 1, 20196 yr Author comment_574647 Many of you have been asking me what is happening and I finally have an update for you, and some info on where I am planning to go in the future. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-574647 Share on other sites More sharing options...
May 11, 20196 yr Author comment_575221 In this episode I delve a bit deeper into the tuning issues on the 680G. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575221 Share on other sites More sharing options...
May 11, 20196 yr comment_575239 Nissan's drawings and explanations really aren't very good at explaining the purpose of the various parts. Edited May 11, 20196 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575239 Share on other sites More sharing options...
May 11, 20196 yr Author comment_575270 2 hours ago, Zed Head said: Nissan's drawings and explanations really aren't very good at explaining the purpose of the various parts. That is a handy diagram. One of my viewers pointed out that the way I have it, any overflow in the tank will go straight into the carbon canister. The easy fix is to just turn the T piece at the fuel filler neck, so that the breather line is facing up not down. Hopefully that will avoid any issues. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575270 Share on other sites More sharing options...
May 12, 20196 yr comment_575297 Jeff, I put a comment on your video. Looks like the big issue you have is too much spark advance. I can tell just by the way it runs and by the way it sounds turning over. Back timing off until it runs best. Been thru this same issue on mine and others cars. Try it and let us know. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575297 Share on other sites More sharing options...
May 15, 20196 yr Author comment_575474 I finally sort out the running issues and no surprises it was my fault. We then tune it up on the dyno and get that final figure. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575474 Share on other sites More sharing options...
May 16, 20196 yr comment_575547 Funny that in this case two wrongs actually made a right. I missed where you told who that guy was that did the final tuning and problem solving. He seemed to know what he was doing for sure. Those washers are called yokes. People have problems with them often, even the header manufacturers don't seem to understand that they need thick flanges on their headers to match the intake manifold flange thickness. Lots of bad header designs out there. Good video, worth a watch. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575547 Share on other sites More sharing options...
May 16, 20196 yr Author comment_575550 3 hours ago, Zed Head said: Funny that in this case two wrongs actually made a right. I missed where you told who that guy was that did the final tuning and problem solving. He seemed to know what he was doing for sure. Those washers are called yokes. People have problems with them often, even the header manufacturers don't seem to understand that they need thick flanges on their headers to match the intake manifold flange thickness. Lots of bad header designs out there. Good video, worth a watch. Yep. I didn't talk about the tuner as he doesn't want to be flooded with calls and more work as he has plenty to keep him going forever ?, but he is basically THE Datsun guy in Aus' and has been building Datsun rally cars forever. As for the washers, I got the engine as a bare block so I didn't know about them and when I fitted the manifold, I didn't really think about it too much. What we actually ( or they to be specific) did, was pulled off the manifold and put it on a mill to match the thickness of the inlet manifold to the exhaust manifold and then they all bolted down nicely. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575550 Share on other sites More sharing options...
May 16, 20196 yr comment_575558 That was a long day at the shop! Good you got it sorted. That is one of the disadvantages of buying a project in a box. Always helpful to have someone who knows how all the details should be Cheers, enjoy! Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575558 Share on other sites More sharing options...
May 17, 20196 yr comment_575634 was that figure at the wheels? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575634 Share on other sites More sharing options...
May 17, 20196 yr Author comment_575635 59 minutes ago, Jason240z said: was that figure at the wheels? It is all in the video ? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=55#findComment-575635 Share on other sites More sharing options...
