59 minutes ago, emccallum said:
With all the plastic on cars today, I would think a good body shop would know how to make it work. I had a plastic bumper on my wife's car repaired and painted about 7 years ago and haven't had any issues.
The difference is modern bumpers are TPO (Thermoplastic Polyolefin) and a urethane bumper is different. I routinely plastic weld TPO bumpers for my cars I repair but Urethane bumpers can't be plastic welded. At least not in the traditional meaning. TPO is also stiff and takes paint better because it's more solid and less rubber like than urethane. Some TPO bumpers for 240z's would be very interesting
@cgsheen1
I was going to post in another thread but didn't want to thread jack, I'm hopeful to make it to Zcon in your area next year and check out your cars
Cody put the seatbelts in the car for me
I reworked the headlights
I used the H4 housing from Toyota and some LED's from Amazon
@SteveJ I still have a high beam indicator issue. The blue indicator is on on low beam and sort of off on high beam. It glows very faintly but I am wondering if that is bleed over from the green LED's in the rest of the guage? Can I simply repin the front plugs to make the high beam on high beam?
Good question. Pull the parking light fuse and see if things change.
Yes, with the parking lights dead, I still have the back feed
I finished cleaning the cigarette lighter up today
Straightened up the bracket and blasted it. Blasted the bottom ceramic with the prongs and polished the chrome rim
I also bought a 123 ignition this week. We installed it today. The car runs again but cylinders 1&2 are still dead. The header pipes don't get hot. The other four are 180 - 200F pretty quick.
We double checked ignition wires. Replaced the ones on 1&2. Checked all 6 with a timing light. Verified spark on the plug visually but no joy. The only thin I can figure at this point is a fuel issue.
We have air, compression and spark. So it seems it has to be a fuel issue.
I will remove the front carb and make sure all the passageways are clear. I don't know what else to do...
I also got the tool covers from resurrected classics and got them installed
A little nerve racking to bend the plastic hinges to mount them
