June 14, 20196 yr comment_577595 It has n47 exhaust liners, round ports and 260z cam... poor mans mods. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-577595 Share on other sites More sharing options...
July 4, 20196 yr Author comment_578971 Actually moving forward again on the motor. The big cam arrived and I can start doing lash pads . Should get lucky and have just two sizes , and I have a set for the one size. Short block is just where I left it - all assembled under the bench. Things should roll pretty fast now. I was hoping for this high drama push to put the big motor in at the last minute to make it to Z con- but reality just kicked my arse again. Be glad to take the 2.4 ! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-578971 Share on other sites More sharing options...
July 14, 20196 yr Author comment_579560 Well my 190 lash pads arrived yesterday so I am chumping at the bit to get going on assembly, trying to take a deep breath before start. Don’t want to rush this . Biggest thing to check now is piston to valve clearance . All other projects are put on hold until this thing is assembled ! Also think I snagged a G-force t-5 trans to mate up with this. For those not familiar it is the Nissan T-5 from the ZXT that gets its guts ripped out and replaced with WC T-5 guts. Larger main shaft and tougher gear sets . Pro- tower shifter , hydraulic TOB! The beauty is that you get a trans that is good for 600 hp , better gear ratios and it just bolts up! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579560 Share on other sites More sharing options...
July 14, 20196 yr comment_579586 4 hours ago, madkaw said: Well my 190 lash pads arrived yesterday so I am chumping at the bit That's a new one. How about chimping? Which is worse... Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579586 Share on other sites More sharing options...
July 14, 20196 yr Author comment_579613 How about chomping ! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579613 Share on other sites More sharing options...
July 20, 20195 yr Author comment_579960 Lash pads installed ! .525 lift and still room for the valves and pistons to share. Waiting on a adjustable cam sprocket and still debating on the balancer . Thinking about spending the $$ because I want to use it on my L32 eventually . Also waiting on some hardware to finish buttoning up things . Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579960 Share on other sites More sharing options...
July 20, 20195 yr comment_579963 Nice!! What head gasket (thickness) was used and how tight was it between pistons and valves? Is the head shaved and how much in that case? //Andreas Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579963 Share on other sites More sharing options...
July 20, 20195 yr comment_579964 That was a good idea for a dial indicator mount surface! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579964 Share on other sites More sharing options...
July 20, 20195 yr comment_579972 11 hours ago, madkaw said: Lash pads installed ! .525 lift and still room for the valves and pistons to share. Waiting on a adjustable cam sprocket and still debating on the balancer . Thinking about spending the $$ because I want to use it on my L32 eventually . Also waiting on some hardware to finish buttoning up things . Did you have to remove any material off the 190 lash pads? If you did would you mind sharing your method? Thank you Steve. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579972 Share on other sites More sharing options...
July 20, 20195 yr Author comment_579973 6 minutes ago, siteunseen said: Did you have to remove any material off the 190 lash pads? If you did would you mind sharing your method? Thank you Steve. Why would I remove material? I figured the size I needed and ordered the correct ones Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579973 Share on other sites More sharing options...
July 20, 20195 yr comment_579977 I bought a cam kit that came with 190s. It's a .460 lift. Thank you for your reply. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579977 Share on other sites More sharing options...
July 20, 20195 yr Author comment_579981 1 hour ago, siteunseen said: I bought a cam kit that came with 190s. It's a .460 lift. Thank you for your reply. So what size do you need? The lash pads are available . Have you done a wipe with stock pads? Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=12#findComment-579981 Share on other sites More sharing options...
