Skip to content
Gas Tank Vent Hoses How Specific Do They Have To Be
I need to finally replace my old vent hoses on my 71. I am seeing pieces of what I believe to be aged rubber showing up in my clear fuel filters. I saw one of the old hoses back by my tail light, and it specifically said "Not for fuel use " on it! Duh. Do I need to purchase the kit of specific hoses for the 240Z, or can I just locate fuel approved hoses that are long enough to be able to fit. I have found one kit with all hoses online for 225 dollars. Seems a but steep for rubber fuel line. i seem to recall one of the hoses takes a few turns and the OEM part is most desirable, but can other cheaper hoses work? What diameter are these hoses anyway?
i've seen a few posts where folks have stuffed a piece of spring inside the hose that does the sharp bends to keep it from collapsing/pinching from the bend. you can usually find a good selection of springs at the hardware store. others will have more complete info on hose size, but i can't see why regular fuel line wouldn't be fine for the vents.
i think the $$$$ kits are really about having concours-correct, cloth braided, OEM stuff in there, which is sure to make your z run better, boost power by 10% and score points with all the ladies...  ;)
Springs for bending hoses: https://www.google.com/search?q=goodyear+hose+bender&ie=utf-8&oe=utf-8#q=goodyear+ez+coil
Now if you want OEM hoses, you can search http://www.carpartsmanual.com for the part numbers and check with a dealership if they are available. Courtesy Nissan has a feature to search to see if a part number is still available: http://www.courtesyparts.com.
I bought all fuel hose rated diameters at O'Reillys. Quarter inch to five eights. Cost $68 including the clamps.
Somebody tell me how I screwed this up, but the car ran perfectly (until I pulled the motor) and I had no fuel smell.  Using this diagram graciously made by Travel'n Man:
  • removed the vapor tank completely
  • discarded green hose, capped vent on tank
  • discarded blue hose, capped vent on tank
  • discarded yellow hose
  • connected orange vent on tank to yellow vent on fuel filler
By "discarded" i mean "allowed to disintegrate after touching".  I kept the vapor tank just in case but i cant say I've missed it.  This is how the fuel venting works on dirt bikes and the few classic vehicles I have worked on that existed before emissions regulation existed.
post-22465-0-08044900-1428426115_thumb.j
How is your tank vented if you capped the vents?  I am trying to do the same.
