July 6, 201510 yr Author comment_473301 And no specific Datsun instructions, but I do have a cam card. Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473301 Share on other sites More sharing options...
July 6, 201510 yr comment_473305 Jump a train to Memphis. You gotta go! Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473305 Share on other sites More sharing options...
July 6, 201510 yr Author comment_473308 Waiting to call Isky Edited July 6, 201510 yr by madkaw Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473308 Share on other sites More sharing options...
July 6, 201510 yr comment_473313 Waiting to call Isky Hmm... how stiff is that mounting plate bolted to the front of the head? Some sort of Tin Plate? Looks a bit flimsy.... Edit: Looks like a backing plate for an electrical junction box.  Any slightest movement there is going to be multiplied by the lever action of your Dial Indicator mounting arm.  I prefer to make a metal rail out of flat 24" x 2" x .125" mild steel and bolt it down the side of the Valve cover rail. Drill holes in it to match Valve cover holes and bolt her down with 3 short 6mm bolts. That way you can attach the Dial Indicator Arm with the shortest length possible and a have a very stiff mounting plate. Stiff is always good !!! Just my .02c.. Edited July 6, 201510 yr by Chickenman Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473313 Share on other sites More sharing options...
July 6, 201510 yr comment_473316 For stock 240z Cam sprockets:  0° (position 1)  Cam Advance  4° (position 2) 8° (position 3) 9° (position 1 + 1 chain link) 13° (position 2 + 1 chain link) 17° (position 3 + 1 chain link) 18° (position 1 + 2 chain links) 22° (position 2 + 2 chain links) 26° (position 3 + 2 chain links) 27° (position 1 + 3 chain links)  Cam Retard-1° (position 3 - 1 chain link)-5° (position 2 - 1 chain link)-9° (- 1 chain link) Note: Crank Advance is Cam Advance/2  Edited July 6, 201510 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473316 Share on other sites More sharing options...
July 6, 201510 yr comment_473317 ChickenmanI believe that is a cover plate for a 4x4 metal electrical box. They are pretty stiff. You could bend it if you tried but they aren't overly flimsy. Not as stiff a 1/8" plate though. Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473317 Share on other sites More sharing options...
July 6, 201510 yr Author comment_473318 waiting on Ron to call me back, but he said the cam card is WRONG! Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473318 Share on other sites More sharing options...
July 6, 201510 yr Author comment_473323 Richard, good call on the box cover. It actually fits the bolt spacing perfectly-no drilling. Yes it's not very thick, but there isn't much pressure being exerted pushing a dial indicator rod in. Hell, the engine stand bounces around more-. I looked at my Schneider card from my 480 lift cam and I realize now how far off the isky numbers are and how close mine probably are to being right. At least I can put this puppy together if Ron ever calls back Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473323 Share on other sites More sharing options...
July 7, 201510 yr comment_473335 Curious as to what the Isky cam specs will actually be. One of the Cam profiles that a lot of guys run up in the PNW is a Shadbolt M445 grind. This was developed way back in the 70's. Still a good cam to this day. 280 advertised duration. Timing was Intake opens 30 degrees BTDC, closes 70 degrees ABDC. Exhaust opens 70 degrees BBDC, closes 30 degrees ATDC. Pretty sure Lobe Centerline was 106 degrees. Lift was .480". Was a pretty darned good Slalom and Race cam. Good power to 7,500 RPM on an, L18 or L24. L16 ( 8,000 rpm ). Worked well on the street. Needed at least 3.90 gears though. L16's liked 4.11 or 4.36 gears. Bottom RPM range depended on displacement. L16 was pretty peaky. Worked really well on a L18 or an L20B with a 4 banger. Awesome cam on an L24 or bigger as well. Edited July 7, 201510 yr by Chickenman Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473335 Share on other sites More sharing options...
July 7, 201510 yr comment_473339 Richard....Stage III Isky Cam is .490 lift; Intake 36-74; Exhaust is 74-36 duration is 290 degrees..... at .050 duration is 242 degrees. Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473339 Share on other sites More sharing options...
July 7, 201510 yr Author comment_473340 and........the numbers are in. Cam card says      Intake                                        exhaust open 2.5BTDC                            open  40.5 BBDCClosed  40.5 BDC                        closed   2.5 ATDC  My numbers on #3 hole sprocket Intake                                          exhaust             3 BTDC                                  43 BBDC39  BBDC                               2 ATDCSteve, Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473340 Share on other sites More sharing options...
July 7, 201510 yr comment_473341 Richard....Stage III Isky Cam is .490 lift; Intake 36-74; Exhaust is 74-36 duration is 290 degrees..... at .050 duration is 242 degrees.That's a pretty stout cam ( Isky L-490 ) . Might be a bit much for the street, but should be good for track days. The M445 Shadbolt is more of a Stage II... FWIW. Isky L480 specs are very close to Shadbolt M445. Lobe Center Angle isn't shown though which is important. But if I recall correctly, Isky likes to use around 106 -108 on the Stage II and III grinds and 103 - 105 on the Race grinds ( Z-196 and Z-273 ) for the L series. Edited July 7, 201510 yr by Chickenman Link to comment https://www.classiczcars.com/forums/topic/50936-l24-rebuild-again/?&page=8#findComment-473341 Share on other sites More sharing options...
