What’s my first move?? - Page 6 - Open Discussions - Classic Z Car Club Skip to content
My first L28 leaked coolant from the head gasket seam at that back corner.
And that hose fitting will come right out with a big wrench. Normal thread direction, righty-tighty. Use some pipe dope/sealant on the threads when you reinstall it. Rectorseal 5 is good, you can get it at most hardware stores.
https://rectorseal.com/rectorseal-no-5-group/
i really hope that’s not the case. I cleaned up the area after the new valve cover gasket and so far it seems dry to the bone 🤞
Here is my fuel filter cocktail 😅
Id drain the tank if haven't. O'Reillys has the filter pretty cheap. Do the G3 pre filter. O'Reillys has their store brand, I think fram is no more?
https://www.atlanticz.ca/zclub/techtips/fuel/g3filter/index.htm
Run the new clear pre filter and check it out. You may need a tank cleaning and coating, that's rusty looking. About as bad as a 240 I bought.
Edited by siteunseen
Those heater hose fittings are prone to rust especially if straight water is used. They are available new
