Z Car Depot Inc
No image preview
Bumper Bracket to Body Bolt Front Rear 240Z 260Z 280Z
Bumper Bracket to Body Bolt Front Rear 240Z 260Z 280Z - 650-194 (). Bolt and washers for attaching front or rear bumper brackets to the body on Datsun 240Z, 260Z and 280Z, 1970-78.
1 hour ago, DatsunZGuy said:
Z Car Depot Inc
No image preview
56 minutes ago, Yarb said:
Which bumper are you trying to install? 280 or 240 series?
I'm not trying to install a bumper I need to know what thread this 10 mm is. 1.0? 1.25?
Which hole? You could probably buy a small selection at your local hardware store for a few dollars. Try them out and you'll know.
Edited by Zed Head
Go buy some taps to figure out your issue. Chances are it’s 1.25. You’re going to need to clean the threads regardless. Don’t try to install a bolt without cleaning almost every thread you run into.
They are 10mm x 1.25.
I'm not reusing the old hardware so i made my own chase with one of the old bolts and that cleaned them up. thank you for everyones help.
  • Popular Post
Here are the thread rules. Again. For any hardware you are likely to encounter.
4 x 0.7
5 x 0.8
6 x 1.0
8 x 1.25
10 x 1.5 - bolts that thread into the engine block. Trans, head, brackets,
10 x 1.25 - All other M10 bolts, ie suspension and body are 1.25
12 x 1.25 - wheel studs, front spindle to steering arm, trans mount (later), TC rod ends, Flywheel , spindle pins
14 x 1.5 - diff strap bolts, front control arm pins
16 x 1.5 - Crank bolt
20 x 1.5 - Rear Stub Axles
Threaded pipe fittings are all BSPT, A/C and EGR excluded.
There is a 1/4x28 SAE thread somewhere for you to find as a test.
There are 7/16-20 SAE too. Another test.
And what the heck is up with those short fat rear control arm bushing bolts? And why do I have 2 or 3 dozen of them?
The first 7 on the list are the ones you should have taps and dies for on hand at all times. Better yet the thread restoring kind, not the thread making kind.
Print this out and post it on the shop wall.
Edited by zKars
