I'm sure this info is buried in dozens of topics over the years, but I'm wondering is anyone has a list of all the items that become "hot" when the ignition is ON. I'm particularly interested in wires already within the engine bay so I don't have to run yet another wire through a new hole in the firewall.
I'm pretty good at reading wiring diagrams but figuring out this info from my 1972 FSM or the laminated, color diagram I've gotten from www.classiccarwiring.com is quite another matter.
https://www.classiczcars.com/forums/topic/69577-ignition-keyed-wiring/
Thanks a million, SteveJ. You've saved me hours of trying to track things down in various wiring harnesses. Now, I can just tap into the FLASHER wire coming out of the fuse box and activate the relays for the AC controls, the AC trinary switch (in the engine bay) and the two DRLs (Daytime Running Lights). I'll probably modify things to use the fog lamp wires to reach the DRLs.
But, my goodness, there are a LOT of connectors coming out of the dash. I'm glad I have another '72 that's still together to use as a guide when my eyes get crossed trying to decipher the FSM wiring diagram.
Does anyone have an idea of the location of that inline fuse for the electric fuel pump? I added a NISMO pump and it's hooked up to the appropriate wires on the rear of the body harness but I'd be well served to know where that fuse is... just in case.
If you are looking for a wire out in the engine bay that goes hot only when the ignition is ON, I think your only* choice is the B/W wire going to the voltage regulator.
*There is also the same B/W wire going to the coil (+) side, but I'm thinking it would be better to keep your connection away from the ignition system if possible.
Both are under the center dash. In the blower switch harness is a BLUE that is A/C power. And there is also a 2-pin connector with a B/W and a G for power to the fuel pump. I always put an inertia switch in that circuit.
I agree with you, Captain, and patcon that I should avoid the B/W associated with the VR and coil as there will probably be enough issues with the electrics once I get everything back together and try starting the car. Running another 16 AWG wire into the engine bay isn't that big a deal.
Excellent advice on an inertia switch, cgsheen1. Do you have a preferred brand and, perhaps more importantly, location for mounting such a device?
I was once a passenger in a car that was forced head on into a concrete median barrier by an aggressive driver, thankfully the impact was at low speed, and its inertia switch operated. I recall the driver having to reach down near the E-brake pedal to reset it so we could continue on to our destination.
I'm no expert but in the inertia switches I've installed I've mounted them to a hard point so any energy exerted on the unibody could be picked up by the switch.
As I was working on the car today, it occurred to me that perhaps the best KEY-ON signal I could hope for in the engine bay would be one coming from the alternator. After all,it will only have an output when the car is running.
I have an internally-regulated 70 amp, 280ZX alternator so I won't be using the 1972 OEM voltage regulator. In fact, that location on the inner fender is where I'm clustering all the relays for headlights, electric cooling fan, etc.
  • What do you folks proficient in S30 electrics think of this as a possibility?
I don't think that is going to work. None of the connections on the back of the alternator will do what you want.
The connection that you are thinking of as "only having an output when the car is running" is connected to the battery. So regardless if the car is running or not, that wire will be at battery voltage.
What would be the reason for avoiding the coil power supply if a relay is used?
If you're using an internally regulated alternator and it's wired correctly the L(amp) wire might work if you connect between the diode and the alternator.
Or, since you've rewired for the ZX alternator there might be a leftover wire that was used for the regulator. You probably used L but did you use IG? Might just be sitting there waiting for you.
Edited by Zed Head
