Interesting electrical issue- Series one car......
I thought that relay was for the Hatch defroster? I could be wrong. I don't think it is as turn signal flasher though, they are the round 2 wire canister looking ones.
Interesting, so where on the series one car is the flasher relay for hazard? I see the one under the steering wheel, don't see the other one........
Does the "accessory relay" control the heated glass?
Here is a general guide to the relays. There are two on the passenger kick panel one called acc. and one for the rear hatch. I seem to remember a flasher relay over there too.
I thought the series one cars do not use a relay on the rear glass since there is no lighted switch....... I know the first 240z had no defroster.... Mine does have the lines on it with a black switch on the console....
Here it is over hiding against the passenger side relays just behind the vent pull rod.
Cool, super helpful. I found it sitting right where you show it..........
Switched the hazard and turn signal flasher, and the turn signal still work. No hazards.......
I got out the factory wiring, and it shows the blue / white wire should be 12V from the fuse box. I just used my meter
and I don't have 12V at the wire at the flasher. Actually no 12v on either wire.....Will go check the fuse box again,,,,,,,,
I did noticed that when I have the hazard switch turned on the turn signals don't work. As soon as I turn the hazards
off, the turn signals work fine. That looks to be correct with the wiring diagram and give me "some" assurance that the
hazard switch is working correctly......
5 hours ago, WJ4Fun said:
That is the accessory relay.
On my mid-1970 car, that accessory relay sends power to the rear defroster and the heater blower. I don't know how frequently they were making changes to the wiring system, but I suspect your 1/71 is the same.
Does any of that info matter to your turn signal issue? No. Haha!! ☺️
I've been maintaining a wiring diagram for the early cars. It's currently version 8, and you can find a copy here:
https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/page/7/?&_rid=23457#findComment-676548
It's not large or laminated, but it's accurate.
Edited by Captain Obvious
