Posted Tuesday at 06:31 PM2 days comment_676704 Installing new shocks in my "72" (KYB) and am wondering what this is that came out of the top spring perch? See picture.Was this just caked in dirt or remants of something else?Thanks! Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/ Share on other sites More sharing options...
Tuesday at 07:46 PM1 day comment_676706 Need more of a descriptive finding. Does it crumble in your hand like sand or is it old dry rubber? Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676706 Share on other sites More sharing options...
Tuesday at 08:13 PM1 day comment_676707 Might be the "spacer". Part #13. I actually bought a pair for my car from Courtesy Nissan long ago. Not sure if you can find them now. It's just a hard rubber ring.Datsun Z Rear Suspension (Strut,...Datsun Z Rear Suspension (Strut, Shock Absorber & Transve... Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676707 Share on other sites More sharing options...
Tuesday at 08:27 PM1 day comment_676709 Part 4949ASSY-INSULATOR STRUT 54320-E4100And still available from Nissan. https://www.nissanpartsdeal.com/parts/nissan-insulator-strut~54320-e4100.html?vin=&make=Nissan&model=Frontier&year=2024&submodel=&extra1=&extra2=&filter=(r=1686) Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676709 Share on other sites More sharing options...
Tuesday at 08:39 PM1 day Author comment_676710 @Yarb I just cound't tell if was sand or rubber like.....maybe more sand.This came from under the top spring perch not above like the spacer and insulator.I was thinking more along the lines of a bump stop?Was there Bump stops?Thanks for the input. Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676710 Share on other sites More sharing options...
Tuesday at 08:45 PM1 day comment_676711 Part 46NLA46ASSY-BUMPER BOUND 54050-E4101L24-2 SEATER,2 SE ATER2 54051-N340074092 54051-N34002+2 SEATER73102 Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676711 Share on other sites More sharing options...
Tuesday at 10:02 PM1 day comment_676712 1 hour ago, SteveE said:This came from under the top spring perch not above like the spacer and insulator.I was thinking more along the lines of a bump stop?Part 13 is below the insulator. It is small. Part 46 from SteveJ is a large part, apparently for a Nissan Pathfinder. Not sure if he's recommending an alternative. ???There are aftermarket bump stops. But they are placed aorund the sliding strut shaft. Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676712 Share on other sites More sharing options...
Tuesday at 11:14 PM1 day comment_676716 Actually the picture and part number is from the front suspension parts microfiche that is on carpartsmanual.com. If it says Pathfinder, it's because they used the same part on it. Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676716 Share on other sites More sharing options...
Yesterday at 12:12 AM1 day comment_676718 The front struts have a bearing under the isolator. Part #53 in your picture. I assumed that this was about the rears because no bearing was shown or mentioned.Anyway, some good leads to follow. Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676718 Share on other sites More sharing options...
Yesterday at 10:25 AM1 day comment_676741 Yes, which strut is that? Front or rear?In the front is a bearing about 40mm OD in the rear is a hard rubber disc with the same dimensions Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676741 Share on other sites More sharing options...
Yesterday at 12:59 PM1 day Author comment_676745 The picture in my first post is the spring side of part #6 in Zed's post.@Patcon This is the rear strut, The front looks the same.The bearing at front and the spacer at back are there and in good shape. The insulators are also in good shape.But if there were bump stops, mine have perished and are missing in action😍So my question is were there bump stops? Assuming there were what are the recomendations for replacements? Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676745 Share on other sites More sharing options...
Yesterday at 02:50 PM1 day comment_676757 20 hours ago, SteveE said:Installing new shocks in my "72" (KYB) and am wondering what this is that came out of the top spring perch? See picture.Was this just caked in dirt or remants of something else?Thanks!The stamped-metal spring cap, in its OE form, was actually manufactured as an two-part assembly' ('Assembly - Bumper Bound'), consisting of the metal part, along with a molded-rubber 'snubber' (some call it a bump stop) bonded to its underside. When new, the snubber piece started off feeling and acting like rubber. Unfortunately, the material didn't age well, becoming hard and crumbly over time (kind of like the consistency of a dried-out hot-dog bun). I'm pretty sure that the stuff shown in your photo is the remains of the snubber. These days, those snubbers are usually replaced with versions made out of polyurethane. Link to comment https://www.classiczcars.com/forums/topic/69428-suspension/#findComment-676757 Share on other sites More sharing options...
