Posted 6 hours ago6 hr comment_676251 Hi all - Am I able to remove this black panel without weakening the floor (as it seems to be welded or glued to it and is pretty hard)?I pulled up the carpet tonight for a replacement, scrubbed the floor with a nylon brush to remove surface rust, and was able to scrub a small hole in the floor which I don't appreciate. I want to see if there is more under this big black piece (circled in blue), but if it is there to strengthen the floor (as it is very hard), I don't want to start yanking on it.Any ideas what it is? Link to comment https://www.classiczcars.com/forums/topic/69394-black-panel-on-floor/ Share on other sites More sharing options...
