Posted April 13Apr 13 comment_675660 Today, I was putting on some miles to be sure the engine is broken in fully on the Z I recently "finished" restoring. I have a vibration that seems to become noticeable around 70 mph.I have only owned two 240Zs, but I have experienced some driveline vibration with each of them. I was hoping not to have the issue with this one, but it is present. And it is bugging me. First, a simple question: Is it perhaps, normal... for a 240Z to have a driveline vibration? I mean, maybe with me driving modern cars, I just have lost touch with how these old cars really were?How do I describe it? Well, for one, the rear view mirror vibrates and blurs the image I see in the mirror a bit. That doesn't seem right. But, it isn't just the mirror. If I touch the center console, or the padded area of the transmission tunnel, I can feel the "hum" that is happening. And, I can feel it coming through the seat as well. The driveshaft has new OEM u-joints and was shortened and balanced by Carolina Driveline in SC. The rear axles have new, OEM u-joints and when they were installed, measurements verified they had the right amount of axial play. The rear differential has all new bearings and was assembled properly. The differential location is stock - it has not been shifted back as was done by the factory for the 1972 and later cars.I remember that the new engine mounts were thicker than the old ones by a bit. That may have raised the engine a touch. I also recall there being some slop in the transmission mount, which allows for a bit of side to side movement of the transmission. I think I will look at the propeller shaft angularity... to see if that looks off. I am interested to hear how much vibration... or how vibration free... is your Z? Edited April 13Apr 13 by inline6 Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/ Share on other sites More sharing options...
April 13Apr 13 comment_675661 1 hour ago, inline6 said:The differential location is stock - it has not been shifted back as was done by the factory for the 1972 and later cars.Not clear what year 240Z you're driving but Nissan moved the diff back because of vibration. I can't find a reference but it's been well-discussed. The shorter "pre-modification" propeller shaft was/is popular for people doing the 71C transmission swap because the length was perfect.Anyway, maybe you're just experiencing the reason Nissan made a change. I think that it was actually mid-71 but not sure. Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675661 Share on other sites More sharing options...
April 13Apr 13 comment_675663 If I were looking for vibration:WheelsDriveshaftHalfshafts - I would have these balanced Stub axle runoutI also agree with Zed about the reason for the diff shift. That would be my first thing to do. Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675663 Share on other sites More sharing options...
April 14Apr 14 comment_675669 Your vibration description is identical to one I had in my early 71, except mine came on at 80 mph +. I described it as having a 500 lb. bumble bee in the car. The vibration was too fast to be half-shaft u-joints. I tried new u-joints, but they didn't improve the vibration. After carefully cleaning the shaft and upon closer inspection, I found a bit of scuffed paint and the slightest hint of a dent. The dent was only visible in bright sunlight and at the right angle. Off to the local drive-shaft company it went. They retubed it and installed new Spicer u-joints. The only brand of u-joint they would guarantee to not screw up the balance at the time, I reinstalled tyhe shaft and never had any more trouble with it for the next twenty years.. Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675669 Share on other sites More sharing options...
April 14Apr 14 Author comment_675670 Thanks for that info, Mark. So, it seems like I should focus my efforts on the driveshaft. While I had the driveshaft shortened and balanced by a reputable driveshaft shop, I am thinking I will need to have it checked. There are actually several driveshaft shops near me, I found out today. I also am unsure if the alignment of the transmission to the differential is off. I need to check left to right of each as well as vertical angles of the rear of the transmission and the front of the differential. Raising the engine a small amount from stock (via the new motor mounts) may be a factor. I am going to buy a digital inclinometer to help with figuring these angles out. Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675670 Share on other sites More sharing options...
April 14Apr 14 comment_675674 13 hours ago, inline6 said:Thanks for that info, Mark. So, it seems like I should focus my efforts on the driveshaft. While I had the driveshaft shortened and balanced by a reputable driveshaft shop, I am thinking I will need to have it checked. There are actually several driveshaft shops near me, I found out today. I also am unsure if the alignment of the transmission to the differential is off. I need to check left to right of each as well as vertical angles of the rear of the transmission and the front of the differential. Raising the engine a small amount from stock (via the new motor mounts) may be a factor. I am going to buy a digital inclinometer to help with figuring these angles out. For best life and to minimize vibration, drivelines should operate at a slight angle, and not be perfectly inline. The small angle is to ensure that all of the needle bearings will see load and rotate. When I design drivelines for industrial applications I use about 2 degrees of parallel misalignment.That said the likelihood of an automotive driveline being perfectly aligned is probably zero. Edited April 14Apr 14 by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675674 Share on other sites More sharing options...
April 14Apr 14 comment_675678 I had the same thought about needing some angle being necessary to work the needle bearings.Side note about the "AI Overview". It is basically a boiled down compilation of everything available on the internet. Including all of the garbage and nonsense. The tech marketers want us to start believing what the AI algorithms produce. But, really, it should all be ignored and only verified professional sources should be considered. At this point in time, "AI" is good for entertainment purposes only.If you really study the statement below you'll see that it actually says very little, and some of it makes little sense. Like "allow the shaft to change angle". Empty words, really.No offense intended. It's just another of those things to be worried about. The word intelligence does not guarantee intelligence. Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675678 Share on other sites More sharing options...
April 14Apr 14 comment_675679 4 minutes ago, Zed Head said:I had the same thought about needing some angle being necessary to work the needle bearings.Side note about the "AI Overview". It is basically a boiled down compilation of everything available on the internet. Including all of the garbage and nonsense. The tech marketers want us to start believing what the AI algorithms produce. But, really, it should all be ignored and only verified professional sources should be considered. At this point in time, "AI" is good for entertainment purposes only.If you really study the statement below you'll see that it actually says very little, and some of it makes little sense. Like "allow the shaft to change angle". Empty words, really.No offense intended. It's just another of those things to be worried about. The word intelligence does not guarantee intelligence.Hey, no offence taken. You are totally right about AI, you have to read the results carefully and still take what is presented with a grain of salt. Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675679 Share on other sites More sharing options...
April 15Apr 15 Author comment_675697 This video is good as well - much longer and somewhat entertaining actually:https://www.youtube.com/watch?v=YgNZfIR-8Ng Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675697 Share on other sites More sharing options...
April 15Apr 15 comment_675698 51 minutes ago, inline6 said:This video is good as well - much longer and somewhat entertaining actually:https://www.youtube.com/watch?v=YgNZfIR-8NgYep, that guy's got some writing and acting talent. A really good communicator. Very enlightening and entertaining!I think he probably could/should have included an explanation as to how/why the two sides of an unaligned U-joint can turn at different and varying speeds. Maybe it would have been too much, but I think it could involve a little trigonometry, and who wouldn't like that?! Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675698 Share on other sites More sharing options...
April 20Apr 20 Author comment_675766 I found the angles today of the front dampener and the pinion flange: I measured these with the car on the lift. The rear moustache bar is locked in solid - there is no vertical movement at the mounting location. Same for the front diff mount. So, I don't have to consider suspension movement (doing this with the suspension loaded). The angle at the differential pinion flange is 87.1. And the angle at the engine dampener is 89. I should be able to drop the rear of the transmission, hopefully a small amount, to get the angle at the dampener to match. I am glad I didn't use the original motor mounts, which were shorter, and would make this problem worse. Edited April 21Apr 21 by inline6 Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675766 Share on other sites More sharing options...
April 22Apr 22 Author comment_675783 I played around with lowering the rear of the transmission today after work. I backed off the bolts securing the transmission mount (Techno Toys Tuning) to the body to see what kind of change in angle would result. Picture of the mount I have (for use with the 240SX transmission) in the early Z:Backing the bolts off to drop the rear of the transmission more than 5/16 of an inch only changed the angle from 89 to 88.5. I expected more change in angle. Anyway, now I am thinking through various things. I find myself asking why the front differential insulator mount has such a "large" angle to it. First of all, I confirmed that my insulator mount is part number 55415-E4102 (the early one). When looking at the factory workshop manual, the image clearly shows an inclination.As my car is sitting on the lift, I measured the inclination of the pinion flange, and it was 87.1 degrees. Why is it so far away from 90? I mean, the driveshaft is supposed to operate with less than 3 degrees of angularity on the u-joints. If I was able to match the 87.1 at the transmission, that would be 2.9 degrees on each u-joint. And, we all know that when power is applied to the input flange, the nose of the differential lifts upwards (and thus the need for the "arrestor" belt which limits to differentials upward movement at the front).It seems to me, that instead of dropping the rear of the transmission down, it would be far better for me to change the angle of the front pinion flange, by either lowering the front of the differential, or raising the rear of the differential.Since I have used lowering springs to lower the car a bit, it seems to me that it would be more desirable to raise the rear of the differential. However, that would require modification of my stock parts here, perhaps removing the upper washers that have rubber bonded to them and replacing them with flat washers? I went through a fair amount trouble to source these washers as I am fairly certain they are what came originally on my 6/71 car. Further, I believe that the front differential mount, front differential insulator, rear differential mount, and rear differential mount washers are all as original for my car. So, I am baffled why the pinion flange angle is what it is.Am I missing something?How do I confirm that my front differential mount is the correct part number for my car - 55411-E4100 (used up through 6/71)? What is the difference between that one and the later 55411-N3001 used from 7/71 to 7/73 Edited April 26Apr 26 by inline6 Link to comment https://www.classiczcars.com/forums/topic/69334-how-vibration-free-is-your-70-71-240z/#findComment-675783 Share on other sites More sharing options...
