May 18May 18 comment_676201 Get a respirator so you can ignore the fumes and avoid any unnecessary exposure Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676201 Share on other sites More sharing options...
May 18May 18 comment_676203 1 hour ago, motorman7 said:And you are planning to put springs on them thangs, aren't you? Haha!! Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676203 Share on other sites More sharing options...
May 18May 18 Author comment_676204 7 minutes ago, Captain Obvious said:And you are planning to put springs on them thangs, aren't you? Haha!!Yes, they are on order.😄 Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676204 Share on other sites More sharing options...
May 18May 18 Author comment_676205 @Captain Obvious thanks for the info on the alternator. I will check that out when I get to that point. Also, new fusible links and harness firewall grommet just arrived today from jdm-car-parts.com. I will attach them in the next week or two here. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676205 Share on other sites More sharing options...
May 18May 18 comment_676206 Yes, those fuse links are actually mine - just haven't had time to update my site. Hell, haven't even taken a picture! Should probably get on that. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676206 Share on other sites More sharing options...
May 18May 18 Author comment_676214 10 hours ago, zspert said:Yes, those fuse links are actually mine - just haven't had time to update my site. Hell, haven't even taken a picture! Should probably get on that.What is the link to your site? Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676214 Share on other sites More sharing options...
May 18May 18 comment_676215 26 minutes ago, motorman7 said:What is the link to your site?https://www.zzxdatsun.com/ Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676215 Share on other sites More sharing options...
May 21May 21 comment_676288 Early starter fuse link on left and early alt fuse link on right. I'll put it on my site when I have some spare time - retirement is SO BUSY!!Story about recent 5 speed rebuild and my time @ Datsun trans school so very long ago to be posted momentarily Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676288 Share on other sites More sharing options...
May 21May 21 Popular Post comment_676290 Guess I'll put it here as this is, at least to this old buzzard, the path of least resistanceAfter almost 190,000 miles and a bit of bearing noise I decided to give the 5 speed in my 78 280 the business and @ the same time address all of the related issues. At the risk of glazing the eyes of my audience I promise to be brief. I had the rear engine plate powder coated - yes, I know it was clear zinc plated from the factory but I wanted to see what my very excellent powder coater could do and the results are very satisfactory - removed 4 pounds from the stock 24 pound flywheel, had the now lightened flywheel balanced along with a new pressure plate, replaced the rear engine seal, clutch assy - used the Exedy set for probably the 100th + time in my career - flywheel and pressure plate fasteners, ALL of the trans bearings, 2nd and 3rd gear syncros, seals and gasket and had all of the related fasteners, etc. zinc replated. This past Sat I drove the 350 mile round trip to Import Carlisle - touched 100 MPH for a couple of seconds - without a hint of concern.I got those trans parts I could from Nissan - yes, I know there are some cheaper alternatives but I like the guys at my fav dealer. Those bearings that are NLA from Nissan I got from a company in Japan, Amayma. They, Amayma, provide excellent service and excellent prices for parts in the original Nissan packaging. Way back in 1971 the dealer I was working for sent me to Datsun trans school. The school held @ Datsun eastern headquarters in Secaucus, NJ. The dealer provided me with a NEW, just off the boat, 510 2 door for transportation. Yes, a new 510 2 door was capable of an indicated 100+. We were provided lunch at what was, I'm confident, a mob owned restaurant. Our instructor told us we could order ANYTHING on the menu but if we wanted lobster we had to give one day notice. Those were the days. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676290 Share on other sites More sharing options...
May 22May 22 comment_676302 18 hours ago, zspert said: What is that, an ashtray? Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676302 Share on other sites More sharing options...
May 22May 22 comment_676304 It's a pencil tray Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676304 Share on other sites More sharing options...
May 23May 23 comment_676311 On 5/17/2025 at 9:57 PM, Captain Obvious said:I suspect that ground connection to the antenna is NOT simply from connection to the body, but is in fact, a dedicated ground wire leading to the antenna.I think that the 'ground wire' consists of the braided wire shown in this photo of the disassembled antenna assembly from my 1970 Z . The larger, toothed washer gets clamped between the assembly casing and the inside of the fender, while (IIRC) the smaller, smooth washer slips over the antenna mast. The purpose is to ground the mast... Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=7#findComment-676311 Share on other sites More sharing options...
