Skip to content
Odd Bolts in Balance Tube
I salvaged a fitting, barb to male taper thread. A 1/8" NPT 27 threads tap lines up perfectly with the fitting I just pulled. That's what I'm going to chase the threads with, using lots of teflon tape, and install 1/8 pipe plugs. I have lots of brass hex stock available, I'll probably just make my own plugs.
Perfectly? That seems unlikely. It's odd enough that a British thread pitch would be used on a Japanense car in the late 60's/early 70's. Why would British be used on the block and US on the balance tube? Chaos!
Your thread chaser might cut some new threads though. People have used NPT in the oil pressure sender hole and made it work. Soft metal will distort.
Not odd at all. It's the same reason that British Standard threads were used on a "Japanense" car in the 1950s and early 1960s. Nissan's tie-up with Austin.
Wait 'til you hear about Imperial wheel diameters and PCDs...
https://www.nissan-global.com/EN/HERITAGE_COLLECTION/short_story/en_p13-01.html
Edited by HS30-H
I mentioned that somebody plugged holes in the 240z balance tube. I was able to run a 1/8-27 pipe tap into the holes, there was enough metal there to get some good threads. I then sealed the holes with 1/8" brass pipe plugs (which I made) and a turn of teflon tape. What's interesting is that I took off a fitting from a 160z flat top balance tube, a barb to male taper fitting. The threads on my 27tpi pipe tap were exactly the same pitch as the fitting from the 260z balance tube. So perhaps Nissan used different thread standards? On to the next problem, vacuum leak.
Jim
Years ago i discovered that the plug under the fueltank.. is also NOT Metric. So don't try to put a metric in there.. If you have a old tank save those plugs as they are rare.
oh yeah.. As i'm getting fludded with commercials and other sh*t, i'm thinking of leaving this shi tty site.. sorry but i'm verry tired of all that commercials s h i t !!
FWIW.. subscribing to a VPN like Surfshark or Nord, etc... eliminates at least 90% of the ads.
dzcg might be having seller's regret. 🤢
Everyone knows about ad blockers. They work. Good luck.
Some thoughts on the above.
First, the 1/8 pipe thread specs are very similar between NPT and BPT and they would be difficult to differentiate. The 1/8 NPT spec is 27 threads per inch, while the BPT uses 28 TPI. If you are holding a fitting up to a tap and that fitting only has four or five threads on it (which would be typical), it would be very difficult to tell the difference between 27 and 28 TPI.
Second, there were no (what are typically called) "barb fittings" used by Datsun on the balance tube. So if you had something like the below installed, it was a previous owner modification. This is what I think of being called a "barb fitting":
So if you had something like that in the 260, it WAS probably 1/8 NPT, but it didn't come from the factory like that. ☺️
CO, I have to apologize on what I said about the barb fitting taken off the 260z balance tube. I went back and looked at the balance tube, the fitting I have with 27 tpi did not come from the balance tube, it was in the box of parts and I assumed that's where it came from. You are right, you know your stuff. As soon as I get the brake problem solved I'll get back to my mixture adjustment and vacuum leak. Jim
