Hey guys, any good source to get few D washers for fenders? I ordered them through McMaster and it is back ordered like hell 18-19 weeks!!! meaning you never get them. Worst case I have to cut few myself (probably should have done it 2 weeks ago instead of waiting!!!).
https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/
Where would a "D" washer be used on a fender?
I didn't even know what one was so I got on the Google.  And there are several shapes/types that are apparently called D washers.  Maybe add some description?
https://www.google.com/search?q=d+washer
They are the one that look like this. As you go down the bolt row on the fender under the hood section there are these D washers.
The flat part is on the bottom and provides the depth needed so the washers don't stick up above the fenders.
Note Zedsaver shows them with the flat part up. I have always seen them with the flat part down. Now I am not sure of the orientation.
Seems like they have these in stock: https://www.mcmaster.com/96025A221/
You need D washers here on 3 of the holes each side. 2 per side has those rubber bumpers. I am planning to just use all 5 D washers for now. Also flat side goes on the bottom as there is no space, that's the point for having the D washer here. I have few original ones but they are rusted. These new ones are great quality.
Edited by MH77280Z
AKA "clipped washers". I don't see them called for in the parts book for fender installation, my guess is that if you find them, they were likely just cut to suit when required.
Edited by CanTechZ
37 seems to point to the two you need on the inside to attach the headlight housing. Those dont need D washers.
I'm really just here for the puzzle.  Can't find them on carpartsmanual but they do seem to be a thing.
https://bringatrailer.com/listing/1970-datsun-240z-112/
Sorry  I did point to the wrong ones, but the fender to hood ledge uses the same regular flat washer.
Some regular washers might fit. My 77 has all 6 of them flat rusted and I dont have space to fit the regular ones. The McMaster ones work. These ones also fit a bit cheaper. Check your fit: https://www.mscdirect.com/product/details/06772388
I am receiving the McMaster tomorrow and will send a snap.
On my car there are some clipped and some not. Just for reference here is how the part number 08915-43610 decodes, the digits defining the washer type are "915-4" which equals "Washer , Plain Standard".
Just for comparison, the ones on my 7/70 measure 17.8mm OD x 6.7mm ID for both the round and D washers. The D measurement is 15.3mm.
