Even though you put a ton of work into fixing up your old garage, I guess it wasn't too difficult to leave it behind in return for a clean, modern garage already equipped with a good floor, good lighting and three bays (not to mention a separate, two-level barn for storing panels and parts. 👍
On 8/14/2025 at 10:42 PM, Patcon said:
Very cool! Looks like the new shop is a nice upgrade. Looks like you might have more acreage too...
Indeed!
We have almost an acre now, corner lot, with a driveway that loops around to the side road. That end I'm having concrete poured, it's been gravel over the beat up asphalt, and that keeps washing into the street, I've had enough of that in the short time we've been here. Concrete is scheduled to be poured tomorrow.
Edited by HusseinHolland
On 8/15/2025 at 12:33 PM, SteveJ said:
Glad to see you back.
Thank you!
The only thing I have to do on the Z soon, is the outer lip hatch seal - the 3 piece one I put on back when I did all the seals has peeled off along the top. I need to remove the hatch & redo it. If I recall correctly, the best way is the glue it with the 3M black snot & then tape it tight & let it harden in place for several days. I didn't wait with mine.
Vintage is where I bought my complete kit and they recommend not to use the 3 piece kit. They did offer it and it came along with the one piece.
I have one of the one piece ones now, to install. Just have to find the thread where the Z member documents the best way to do the install
@MH77280Z has done this on a 280 if I remember correctly. May be of some help to you.
After seeing what you did to your older garage, I'm a little claustrophobic and it made me cringe, I am so happy for you and your new space. 🙂
; ipsSettings['maxImageDimensions'] = { width: 1000, height: 750 }; const ipsJsFileMap = [];
